Thread Converter Shifter
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jsallyTRDPRO, Feb 19, 2019.
  1. Feb 21, 2019 at 4:37 PM
    jsallyTRDPRO
    jsallyTRDPRO [OP] Member
    Josh
    2019 TRD PRO
    I found out the thread it's 3/4-16
    TomTwo likes this.
  2. Feb 22, 2019 at 5:00 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If you are sure of both sizes any machine shop worth it's salt can easily machine the center of a 3/4" bolt to 12 MM 1.25. I would take them the lever and the bolt and if you can find a nut to fit the shaft you are trying to fasten it to or the lever you are replacing, you probably only want to do this once.
  3. Feb 22, 2019 at 5:18 AM
    salmonmigration
    salmonmigration Well-Known Member
    2018 TRD Sport 6MT
    So you're going from SAE to metric. This won't be an off the shelf part.
    Why don't you go to home depot and check the knob by screwing in one of their 3/4"-16 bolts just to make sure it's the right size.
    Once you for sure know what you need you'll have to get your adapter made somewhere. Looks like American Shifter does this a lot or you can go to your local machine shop like I'd recommend.
  4. Feb 22, 2019 at 7:59 AM
    jsallyTRDPRO
    Josh
    2019 TRD PRO
    Thanks a lot. I go the thread size off their instructions I found somewhere on the internet.
  5. Feb 22, 2019 at 4:27 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Is that what some one said or did you actually try a bolt?
  6. Feb 22, 2019 at 5:08 PM
    jsallyTRDPRO
    Josh
    2019 TRD PRO
    confirmed it with the short throw shifter's manufacturer
  7. Feb 22, 2019 at 5:13 PM
    09 Redneck
    09 Redneck Well-Known Member
    Ga
    jsallyTRDPRO[OP] likes this.
  8. Feb 23, 2019 at 4:59 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    I just visited Barton's site they don't list any thing for a Tacoma or a Toyota for that matter so you are own your own. Are you even sure the stick end of you Tacoma is threaded? In the past they were not in was one piece that went directly into the trans. this of course is assuming you have a stick shift if you don't what good is a short shifter going to do you?
