Thread of Wheels that definitely work (first hand knowledge only)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeepinoutwest, Apr 20, 2012.
  1. Apr 20, 2012 at 10:35 PM
    jeepinoutwest
    jeepinoutwest [OP] Well-Known Member
  2. Apr 21, 2012 at 7:30 AM
    TastyHuman
    TastyHuman Oh. Bummer.
    Stock wheels definitely work.
  3. Apr 21, 2012 at 7:45 AM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    well first off, is your truck a TRD sport or offroad?? if not, then u dont have any worries cuz ur truck prob. came with 16's stock..I have an 05' sport that came with 17's stock and hardly any 16's fit (dont listen to the wheel manufacturer, they are often WRONG) i have the wheelersoffroad black steelies in a 16 x 8 with 4" backspace and that was 1 of the only wheels that would fit. I think there a few others out there, but not much option when going down to a 16 if u already have a 17...just check around
  4. Apr 21, 2012 at 7:54 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    There's no difference in the sport and offroad as far as wheel fitment.
  5. Apr 21, 2012 at 7:57 AM
    oneBIGroom
    oneBIGroom SSS
    SSS
    SSS
    SSS
    SSS
    20"x10" XD Revolvers -24 offset, 4.5 backspacing
    16"x8" Helo 842's
  6. Apr 21, 2012 at 7:58 AM
    reece13
    North Carolina
    u know what i was getting at. basically just saying 16's are hard to clear brake calipers on a sport like mine THAT HAD 17's stock
  7. Apr 21, 2012 at 8:03 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^ Incorrect. The TRD Sport and TRD Off Road have the same brake calipers.
  8. Apr 21, 2012 at 8:05 AM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    Pretty sure you said...
    Which is wrong. They have the same calipers, so there's nothing different. If that's what your rim guy told you, you should find a new cause he threw you threw a hoop...There are plenty of 16's that will fit. There are even people running 15's. Yes, you should check clearance, but most will fit from what I've seen.
  9. Apr 21, 2012 at 8:07 AM
    reece13
    North Carolina
    jesus christ people, i dont care about the diff. in sport in offroad versions. all im trying to say is that THERE ARE ISSUES with some 16's rubbing if U HAD A 17 to begin with. I experienced this. look around on this forum.
  10. Apr 21, 2012 at 8:08 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    theres this on ttora somewhere
  11. Apr 21, 2012 at 8:09 AM
    reece13
    North Carolina
    15's ? what du u have? a 2" wheel spacer or something...............
  12. Apr 21, 2012 at 8:10 AM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    Moto Metal 951 16x8 0 os 4.5 bs fit perfect. But I know there was a thread on here where someone had the same specs on a different wheel that wouldn't fit.
  13. Apr 21, 2012 at 8:10 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    who cares what you had to begin with? if a 16 doesnt fit on a sport...it wont fit the offroad....i have 16s on my sport
  14. Apr 21, 2012 at 8:11 AM
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    There are issues with some rubbing regardless of whether you had 17's or not. Your starting rim size is irrelevant, and attempting to educate people that it is is grounds for :crapstorm: and :duel:
  15. Apr 21, 2012 at 8:11 AM
    floridaoccifer
    floridaoccifer Civil Servant
    16x8 Dick Cepek Torque - ZERO issues you will have to purchase ET lugs
  16. Apr 21, 2012 at 8:19 AM
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    I currently have stock rims. You are the one that informed me to search this forum and find the issues you speak of. I am merely stating that I have seen people on here that are running 15" rims.
    I believe they only fit on 5luggers without mods tho
  17. Apr 21, 2012 at 8:28 AM
    KenLyns
    Belly of the Beast
    16" can rub even if you had a 16" to begin with, too.
    Besides, the OP has a regular cab, which means it doesn't have 17" to begin with.
  18. Apr 21, 2012 at 8:34 AM
    burtonboards32
    burtonboards32 Well-Known Member
    What color is your regular cab? I have read that it makes a difference and you may not be able to fit anything smaller than a 22" rim... So Jesus Christ, you better get a 24" just in case!
