Threading hard line into clutch master cylinder
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BassAckwards, Oct 31, 2018.
  1. Nov 1, 2018 at 8:20 AM
    BassAckwards
    BassAckwards [OP] Well-Known Member
    2009 Tacoma AWD Turbo 2TR-FE
    Yes, master is loose. bottom bolt is completely out, and the top one is barely threaded in, so that I am able to rotate the bottom section of the master where the hard line screws into
  2. Nov 1, 2018 at 8:29 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    I am NOT a mechanic but the end of that fitting looks like it was manufactured that way, I do not think it was flared by over tightening- my rationale: it’s too uniform, the section after the threads looks like it has some flash along the bottom edge that extends to the very end, this too would have been mashed up.
    Looks to me that in addition to getting the angles right, it needs to be inserted then threaded...
    @Bebop , any thoughts?
    BassAckwards[OP] likes this.
  3. Nov 1, 2018 at 8:42 AM
    PzTank
    Above the Notches
    @rjbiii , do you have a nut the same size as the thread in the master cylinder? See if it’ll thread on to your fitting. This could show if the end is mashed or not AND straighten out some of those nicked threads without dicking around with files and such...
  4. Nov 1, 2018 at 8:45 AM
    BassAckwards
    Very good idea, I don't think I have a metric nut like that, but will definitely try to track one down! Didn't even think to do this, very good troubleshooting procedure:cheers:
    PzTank[QUOTED] likes this.
  5. Nov 1, 2018 at 9:11 AM
    PzTank
    Above the Notches
    You can bring your extra fitting to a hardware store and match it up! Good luck!!
  6. Nov 1, 2018 at 11:15 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Have you loosened the clutch cylinder off the firewall. Sometimes it helps if both ends have a little wiggle to them
  7. Nov 1, 2018 at 11:27 AM
    BassAckwards
    like the bracket holding the master to the firewall? or the hard line where it attaches to the firewall? I haven't done either of these, will definitely do so if it helps everything line up though
  8. Nov 1, 2018 at 11:40 AM
    Bebop
    Nick
    Lossen them all. The more wiggle room you have trying to thread in a hydraulic line the better. Less chance of cross threading.
  9. Nov 1, 2018 at 11:41 AM
    BassAckwards
    Will do, thanks Nick!
    Bebop[QUOTED] likes this.
  10. Nov 1, 2018 at 12:39 PM
    Bebop
    Nick
    No problem. Shoot me a pm if you run into any snags
  11. Nov 1, 2018 at 2:33 PM
    Muddinfun
    Muddinfun Well-Known Member
    Looking at the pic, it's obvious that the end of the fitting is mushroomed out larger than the diameter of the valleys in the threads on the fitting. You can see the scratches on the fitting where the mushroomed part scraped on the high point of the threads in the fitting as you were backing it out. You only have 2 choices. File down that part of the fitting or replace the hard line. As much as that fitting has been goobered with vicegrips, overtightened, and bent where it enters the fitting, I would replace the line.
    landphil and BassAckwards[OP] like this.
  12. Nov 1, 2018 at 2:41 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    That's a flare fitting - I wouldn't file anything down to make it fit or it's never going to seal. Muddin is right, replace the whole hard line.
    landphil likes this.
  13. Nov 1, 2018 at 7:13 PM
    BassAckwards
    Got it on finally. Took lightly filing down the fitting on the hard line, and about another 2hrs of trying to get it lined up perfectly. Tightened down the fitting, and no leaks as of yet. Need to bleed the line and adjust the pedal again, but the old girl is moving on her own again. Thank you everyone for all your help and suggestions! Couldnt have done it without yall, as usual, tacoma world always comes through!
    Cheers :cheers:
    TXpro4X4, buyobuyo, PzTank and 3 others like this.
  14. Nov 1, 2018 at 7:25 PM
    Tacosail
    Tacosail Well-Known Member
    Jerry
    Hermanville Heights, Ohio
    '13 white ACLB
    '17 wheels,int. Wipers , bed mat , relocate trailer plug , husky floor liners , Lund nerf bars, wet Okole seat covers- heat & lumbar.
    Good job. You beat it. Feels good , don't it?
  15. Nov 1, 2018 at 7:29 PM
    #35
    BassAckwards
    Feels absolutely GLORIOUS!:headbang:
    TXpro4X4 likes this.
  16. Nov 1, 2018 at 7:30 PM
    #36
    Bebop
    Nick
    Have a cold one!!!!! And I live by the motto, “every 20 minute job is one broken bolt or stripped screw away from becoming a 3 day ordeal”
  17. Nov 1, 2018 at 7:33 PM
    #37
    BassAckwards
    Enjoying one right now!!
    That is a great motto lol. Sounds like what i encounter every time i try to work on my truck with something i have very little experience doing.. shit tends to go wrong for me frequently, but i do learn a hell of a lot during the process of fixing it
  18. Nov 1, 2018 at 7:37 PM
    #38
    Bebop
    Nick
    Invest in a good tap and die kit and some bolt extractors. Thread files come in handy too
  19. Nov 1, 2018 at 7:49 PM
    #39
    BassAckwards
    Good tips, definitely going to add these to my list of tools i need to acquire:thumbsup:
  20. Feb 14, 2019 at 10:08 AM
    #40
    Thetravelingtacoma
    Thetravelingtacoma Member
    What did you use to file down the hard line? I’m in the same situation. I Didn't know what you used to get back into the tight space.
