Threads describing 3rd member removal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bjmoose, Oct 31, 2011.
  1. Oct 31, 2011 at 9:22 PM
    bjmoose
    bjmoose [OP] Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I got a quote from my local differential specialty shop to drive in and have them install my new ARB and gears. (I already have the parts.)
    After I got up off the floor, I asked how much if I just bring in the 3rds. OK, that I can deal with.
    So I looked in my Chilton's guide for description of removing the 3rd. Pretty much unhelpful. Look on TW and on the rest of the web. I'm not really finding any good photo threads here, especially for the front.
    There's this one, which isn't bad, but it is a 1st gen.
    http://www.atarmor.com/3rdmemwriteup/writeup2.htm
    This one has some good insights and info, again for the rear, but not step-by-step.
    http://www.tacomaworld.com/forum/technical-chat/56683-swapping-rear-3rd-member-difficulty.html
    So, can you guys point me to any other good threads and writeups that I might be missing?
  2. Oct 31, 2011 at 9:29 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I don't know of any better threads than those two. The third removal is going to be pretty similar between the 1st and 2nd gens with the main difference being what's inside the third. I was able to take mine out by myself after reading those threads. It was a little intimidating at first, but eventually I had to just do it.
  3. Oct 31, 2011 at 9:38 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    One of the good hints about how well you've searched is, after you've created a thread, what TW gives you as similar threads.
    And there's not a lot down there on this one...
  4. Oct 31, 2011 at 9:46 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    1st gen
    remove d-shaft and unbolt brake lines
    unbolt axle
    pull out axles
    then unbolt the third
    unless im missing something i recall thats it but its way past my bedtime
  5. Oct 31, 2011 at 10:28 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    ^thats how I did mine. If it helps if you have another person to help pull the axles so the third drops. It is pretty straight forward. Just replace the paper gasket or use rtv.
  6. Nov 1, 2011 at 12:02 AM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
  7. Nov 1, 2011 at 3:54 AM
    Wally
    Wally Well-Known Member
    Ontario (the metric version)
    07 Access Cab TRD 4x4 6MT 1GR-FE
  8. Nov 1, 2011 at 8:44 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
  9. Nov 1, 2011 at 8:46 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Specialty Tools
  10. Nov 1, 2011 at 8:58 AM
    Wally
    Special Service Tools
    You don't need them from the dealer unless they are really specific to the vehicle and task, sometimes they're strange one-off items.
    It's a case by case thing, but if I can buy the tools so I can do it myself for the same or less than a shop visit, I'll do it so it's cheaper the next time around.
  11. Nov 1, 2011 at 10:35 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    So, I'm heading down to the hardware store at lunch - it looks like 35mm is the size socket to get for front CV axle removal, despite 36mm being the stated "official" size??
  12. Nov 1, 2011 at 1:14 PM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    IIRC yeah. 35 fits perfect.
  13. Nov 1, 2011 at 2:26 PM
    Wally
    From another thread ... says he can swap out the third member in about an hour. Sounds like a great shortcut.
  14. Nov 1, 2011 at 4:09 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    dude it takes me between 45 min to an hour
  15. Nov 1, 2011 at 4:22 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    What do you plug the end of the brake lines with so you don't lose all your brake fluid or get air all the way to the master cylinder?
  16. Nov 1, 2011 at 4:33 PM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    You can get some rubber caps.
  17. Nov 1, 2011 at 4:34 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Auto supply store?
  18. Nov 1, 2011 at 4:38 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Nothing really. Wad up some shop rags and let them soak it up. Change them as needed every 15 or 20 minutes. You are going to lose some brake fluid, so bleeding the brakes is required when you're done swapping the diffs.
  19. Nov 1, 2011 at 4:38 PM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    Yeah. Something like the caps on your bleeders should work. Maybe a little bigger.
  20. Nov 1, 2011 at 5:36 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    They're going to be out for a week ( pull one weekend, drop at shop on Monday, pick up when completed, reinstall following weekend.) So I need to seal them up well.
