Three ABS sensors and ABS Module
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1lukeduke, Aug 8, 2025.
  1. Aug 8, 2025 at 9:24 AM
    1lukeduke
    1lukeduke [OP] Member
    Lucas
    SoCal
    2002 Tacoma DCab 4x4
    Hello to all! New to me 2002 3.4 Tacoma. Did a lot of searching on this but could not find what I’m looking for. I have an ABS light on. Did the paper clip thing and came up with three ABS speed sensors bad and also the ABS module. I can’t believe that all of them failed all at the same time. The vehicle doesn’t seem to be leaking fluids anywhere. I have cleaned the front speed sensors with no change. Looking for any knowledge on something like this. Thank you in advance for any help.
    Lucas
  2. Aug 8, 2025 at 9:37 AM
    Bolt Head
    Bolt Head Well-Known Member
    Colorado
    Silver 2001 SC DC LTD
    Fox 2.5 w/resi and adjusters, LR UCAs, Wheeler's minus 2 leaf pack, Toytec rear shocks, FN 5 Star w 33" Toyo OC AT3, Pinch-weld mod, Supercharger, Heated/Cooled Leather Seats, Pioneer DVD w/backup cam, Alpine PDX amp, Remote Start, Spray-on bed liner
    Any other symptoms? I had an ABS light on. The ABS would sometimes activate when it shouldn't and wouldn't when it should have. It turned out to be a bad module. Sent it out for rebuild and it's been perfect ever since.
    1lukeduke[OP] likes this.
  3. Aug 8, 2025 at 10:24 AM
    1lukeduke
    Lucas
    SoCal
    @Bolt Head nothing that stands out. Just the ABS light on. I was thinking of changing them out. Then when I checked the price, I almost fainted. And I am used to Toyota OEM prices. These specific parts are absolutely ridiculous.
  4. Aug 8, 2025 at 10:37 AM
    Red_03Taco
    Red_03Taco @ the Taco Shop
    Jerad
    Yavapai County, AZ
    2003 Tacoma Xtra Cab 4WD
    Eaton E-locker (rear), Alcan Leafs, Toytec 2.0s (rear), Icon 2.5s (front)
    Time for the easiest fix ever: ABS disable mod.
    Step 1: Remove ABS fuse.
    Step 2 (optional for OCD folks): Remove ABS warning light bulb behind guage cluster.
    Step 3: Relish the satisfaction of knowing you just saved hundreds of dollars and permanently fixed the problem :bananadance:
    clifpaul and 1lukeduke[OP] like this.
  5. Aug 8, 2025 at 10:40 AM
    Bolt Head
    Colorado
    The price for what? The module?
    1lukeduke[QUOTED][OP] likes this.
  6. Aug 8, 2025 at 10:52 AM
    1lukeduke
    Lucas
    SoCal
    The speed sensors! I haven’t even looked at the module.
  7. Aug 8, 2025 at 10:53 AM
    1lukeduke
    Lucas
    SoCal
    It might get to that I’m afraid!
  8. Aug 8, 2025 at 10:54 AM
    Bolt Head
    Colorado
    Ok, got ya. Well, if it does turn out to be your module and you want to keep your ABS, I know the module "rebuild" is pretty reasonable $$.
  9. Aug 8, 2025 at 11:14 AM
    Red_03Taco
    Jerad
    Yavapai County, AZ
    No need to be afraid. I did that to mine around a year and a half ago now, and have had absolutely no regrets. There is literally no noticeable difference in braking performance or in the way the braking system acts at all.
  10. Aug 8, 2025 at 1:11 PM
    1lukeduke
    Lucas
    SoCal
    I think it may be the call for now at least. It stops great right now!!!
  11. Aug 8, 2025 at 3:22 PM
    Red_03Taco
    Jerad
    Yavapai County, AZ
    And its always reversible by just plugging the fuse back in.
  12. Aug 13, 2025 at 8:31 AM
    1lukeduke
    Lucas
    SoCal
    I removed the 60a fuse but still have the light. Is there another fuse that I need to pull to make the light go out?
  13. Aug 13, 2025 at 8:52 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Gotta pull the light itself.
  14. Aug 13, 2025 at 9:03 AM
    Glamisman
    Glamisman Well-Known Member
    On all of the systems I have had the mis-pleasure of looking at there are 2 self tests so I am assuming Toyota is the same. There is a immediate electrical test and then after the vehicle gets above 5 mph there is an actuation test. Does your ABS light light up immediatly or after the truck starts rolling.
  15. Aug 13, 2025 at 9:37 AM
    1lukeduke
    Lucas
    SoCal
    It is immediately. I just can’t believe that it’s four of the five things that could set out off. Unless there was some short, but I would think that one of the fuses would blow.
  16. Aug 13, 2025 at 12:36 PM
    Red_03Taco
    Jerad
    Yavapai County, AZ
    The light is on to "alert" you the fuse is pulled. The system is disabled, mission accomplished. If the light bugs you, then pull it out (thats what I did).
  17. Aug 13, 2025 at 1:04 PM
    Glamisman
    I am a follow the data/diagnose it type of guy in 99% of my repair situations and the 1% of the time is this. I see that Amazon has aftermarket wheel speed sensors for $20. I will plug in a $20 test part first thing and it that sensor fault goes away you have saved diagnose time. If the part was $200, thats a different thing.
    I agree, all three at the same time, odd... are there signs of mouse activity anywhere? Where is the ECU for the ABS located in the truck.
    1lukeduke[OP] and shankyjones like this.
  18. Aug 13, 2025 at 5:10 PM
    1lukeduke
    Lucas
    SoCal
    It is in the engine bay. I’m with you but this is way down the list of things to fix. The new Toyota ones are over $250 each. The light bothers me, so I will pull it. I need to put a new bulb in the cluster anyway. Thank you all!!!
    Red_03Taco likes this.
