Threw a P0022 Code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by saf023, Apr 6, 2012.
  1. Apr 6, 2012 at 5:11 AM
    saf023
    saf023 [OP] Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    Yesterday while driving to work I decided to roll the windows up and turn on the AC. A check engine light immediately appeared. I used my ScanGauge to check and clear the code. The code was P0022. I believe P0022 is an "A" Camshaft Position - Timing Over-Retarded (Bank 2). After I cleared the code, the check engine light did not come back. The engine feels like it runs fine and there appears to be no change in gas mpg.
    - Should I be concerned and if so, what should I be concerned about?
    - Should I watch for anything specific?
  2. Apr 6, 2012 at 9:30 AM
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    Rare code to see on a Tacoma. More common on the 3UR V8's in the Tundras. Anyways, if it dosnt come back on, don't worry. If it does, probably needs a newnVam gear on the left side for the VVT-I.
  3. Apr 6, 2012 at 5:48 PM
    saf023
    East Coast
    Thanks for the information 1GR but what gear are you suggesting?
    Thanks.
  4. Apr 6, 2012 at 10:46 PM
    1GR
    Scott
    BC, Canada
    Bank 2 (left side) intake cam gear.
