throttle and butterfly valve question
Discussion in '1st Gen. Tacomas (1995-2004)' started by slickyd, Aug 15, 2012.
  1. Aug 16, 2012 at 3:01 PM
    NYTaco04
    NYTaco04 Member
    Brian
    Conesus, NY
    04 TRD
    The 03 and 04 V6 have an accelerator pedal position sensor. It is some sort of potentiometer that controls the voltage to a throttle control motor located on the back side of the throttle body. It is the throttle control motor that opens and closes the butterfly valve in the throttle body. The cable in that picture is attached to the APPS. Like Hoss said, with the truck off, the mechanical part of the APPS will only open the butterfly valve after you pull the cable about 50% of the way. Try this, with the key in the "on" position, pull the throttle cable. The response of the butterfly valve should now follow how much you are pulling the cable. If you google "tacoma APPS", you will find many posts stating issues with intermitent acceleration problems pointing to the APPS. I've heard it best described as it feels like your foot sliding off the gas pedal. Good luck.
  2. Aug 16, 2012 at 3:12 PM
    slickyd
    slickyd [OP] Well-Known Member
    David
    Talladega, AL
    03 PreRunner SR5
    I took it to toyota in December and they couldn't figure out what was wrong with gas mileage.
    I'll read up on that "apps". Thanks for your help.
  3. Aug 16, 2012 at 4:37 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    is the tailpipe really sooty and black? Is your mpg around 13? If so you may have a failing Air Fuel Ratio sensor. Mine took a few months to fail and throw a CEL.
  4. Aug 16, 2012 at 5:43 PM
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    I think it might be sooty but il have to check on my break to be sure. It does have "smoke" or something you can see coming out of it. And it gets about that in gas milage. I use to get around 19 mpg.
    I have ben reading some more on the forum and I found a better way to describe what the truck is doing. With my foot not moving staying at a constant speed my truck will stop responding but its so fast i can't get my eyes on the rpm's to see if its dropping. That and the strange exhaust and bad gas mileage.
  5. Aug 17, 2012 at 7:13 AM
    BamaToy1997
    Bill
    Navarre, FL
    As I recall every model since also has this, not just the 03 and 04 models.
    I did some research to clarify what I thought was proper operation. I was wrong, the cable does go to the gas pedal, and is used to actuate the APPS as mentioned, and for "limp home" mode if the ASCD system fails. NYTaco is correct on testing procedure for the ASCD system.
  6. Aug 17, 2012 at 7:29 AM
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    Ok thank you all I'll be working on it this weekend I'll report back with what I find.
  7. Aug 18, 2012 at 3:04 PM
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    Ok need to know something. Called toyota this morning and price the tps and they tell me I that the 01-02 can just replace the tps but the 03-04 have to replace the ENTIRE THROTTLE BODY! Which is $1200 compaired to $60 for just the tps. So can I just get the tps and replace it? It would be nice if someone has done this on a 03 or 04 could tell me if it worked for them.
  8. Aug 18, 2012 at 3:05 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    i would think you could but i am not sure
  9. Aug 18, 2012 at 3:16 PM
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    Yeah I know but what does everyone else say?
  10. Aug 18, 2012 at 7:06 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    hey, that does sound strange, I replaced the one on mine a few months ago, (yes I have a granny truck). now I don't know this person, but have seen the ad on craigslist for a few months, don't know if it would help, but here it is,
    http://chicago.craigslist.org/nwi/pts/3199205136.html
  11. Aug 18, 2012 at 7:47 PM
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    I sent the guy an email.
  12. Aug 18, 2012 at 8:02 PM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    that is a strange problem but I'd be damned if I would spend 1200 on a new TB its a truck not F1.
  13. Aug 19, 2012 at 7:24 AM
    NYTaco04
    NYTaco04 Member
    Brian
    Conesus, NY
    04 TRD
    I have heard the same thing as far as replacing just the TPS on an 03 or 04. Sorry that I can't confirm it though. I know the APPS and throttle control motor cannot be purchased from Toyota without buying the entire throttle body, but unsure of the TPS. Did you try visually watching the butterfly move with the key on? I'm sure that there is a testing procedure for the TPS with an ohm meter if you knew what the specs. for it were. No way in hell I'd buy a $1200 throttle body without knowing more.
  14. Aug 19, 2012 at 3:13 PM
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    I just checked it sounds like it is opening a soon as I turn the throttle switch. I'm in town about to eat so i can't take the income house off to see. I can't believe no one has replaced this on an 03 or 04.
  15. Aug 19, 2012 at 9:58 PM
    #35
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    Does anyone know the part number for the accelerator pedal position sensor? I googled it and it just comes up the tps and I can't find the part on a couple of part websites?
  16. Aug 20, 2012 at 7:28 AM
    #36
    NYTaco04
    NYTaco04 Member
    Brian
    Conesus, NY
    04 TRD
    The APPS is not available by itself.
  17. Aug 20, 2012 at 7:57 AM
    #37
    BamaToy1997
    Bill
    Navarre, FL
    While the APPS is not available, the TPS sensor is, if that is what you are talking about replacing. Be aware that the APPS sensor and TPS sensor are two different parts. The APPS sensor is there to detect basically how far you have pressed the gas pedal, while the TPS measures the actual position of the throttle plate.
    If the TPS sensor is what you need, you can find it at Rockauto.com for $42.79 plus shipping charges. The Rockauto part number is TH207
  18. Aug 20, 2012 at 3:00 PM
    #38
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    Update: cleaned the MAF sensor and so far so good. It hasn't stopped responding and its stopped the funky smell from the exhaust. Hope it will stay that way. Thanks to all of you fire your help.
  19. Aug 20, 2012 at 4:33 PM
    #39
    NYTaco04
    NYTaco04 Member
    Brian
    Conesus, NY
    04 TRD
    Cool, hope it stays running well. It's always nice when it is something simple.
  20. Aug 20, 2012 at 6:14 PM
    #40
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    Yes it is.
