Throttle Body 3.4L 2004 Tacoma Prerunner Blues
Discussion in 'New Members' started by BG1963, Nov 7, 2016.
  1. Nov 7, 2016 at 3:33 PM
    BG1963
    BG1963 [OP] New Member
    2004 Prerunner 3.4L
    None
    Hi. I own a 2004 Toyota Tacoma Prerunner, 2 wheel drive, automatic transmission, 3.4L engine. My truck sat underwater, completely submerged except for the roof, for 2 days due to a flood we had here in Louisiana about a month ago. Decided instead of letting FEMA give me a couple thousand dollars I'm going to fix it myself. Cause I like my truck. I've removed the dash and interior, drained all fluids and replaced, got the water out of the engine, cleaned accessories under the hood and started it. It runs. I have so far one problem. The throttle body apparently. What's happening is this; With engine running I've found that there is much slack in the accelerator pedal where there was none before. The butterfly valve will open almost half way with no response in rpm's. The throttle body has the TPS mounted on it on the firewall side and what best I can tell a accelerator position sensor mounted on the other side towards the radiator side. This sensor has a electrical connector on it and a single cable running to the acc. pedal. And a dc motor in the bottom of the body. It also has a ECT switch in the dash. Can anyone tell me what could be my problem? And the proper names for these components. With a diagnostic computer hooked up to my truck the codes I get are P2102 and P2121. I am not a mechanic and do not have years of experience with electronics and all these sensors but I've got this far and as I said it is running, transmission is working along with the a/c, heat, and lights. I'm just having trouble understanding how the throttle body works electrically and the exact function of the dc motor. So far. Thanks, any info and advice would be much appreciated
  2. Oct 10, 2020 at 12:36 PM
    Dmarsh22
    Dmarsh22 New Member
    David
    2004 tacoma
    Samurai body and frame
    I have the same rig and the same exact problem. I’ll let u know if I figure it out
  3. Oct 10, 2020 at 12:39 PM
    eon_blue
    Azusa, CA
    @Running Board Man had his 1st submerged in a flood a couple years ago and brought it back to life. There's a big thread on it here somewhere.
    Then he totaled it on the highway but that's another story
  4. Oct 10, 2020 at 3:40 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  5. Oct 10, 2020 at 3:55 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You have the same codes?
    Do you know what codes you have?
  6. Oct 10, 2020 at 5:38 PM
    Running Board Man
    Running Board Man Well-Known Member
    04 vs 95 are Different animals entirly I wouldn't try to save something as electronic as an 03 or 04 tacoma/01 or 02 4 runner
    Without water my 01 4 runner gave me enough headaches
    eon_blue[QUOTED] likes this.
  7. Oct 10, 2020 at 5:45 PM
    Running Board Man
    Op, the throttle body is entirely electronic, you probably just need to replace it
    How it works is the throttle cable turns the shaft that goes to the tps that sends a signal to the ecu than the ecu send a signal to the servo motor in the tb to open the throttle valve
    Theres a mechanical override that will open the throttle valve 1/3 when full throttle if all is functioning fine but the motor in the tb goes out you should have that 1/3 throttle
    Also depending if you have stability control unplug a wheel speed sensor and see if you gain throttle again on my 4 runner I had air in the brakes so the throttle stopped working because the stability control system detected something wrong
    same thing happened when a wheel speed sensor got wacked with a hammer... I decided to just leave it with the lights on and system disabled
    Depending if you have the push button t case or not open up the actuators and re apply grease make sure to not fuck up the orientation of the plastic gear in the actuator if you end up doing it do this for the front diff actuator j shift or push button
    TnShooter likes this.
  8. Oct 10, 2020 at 9:32 PM
    Dmarsh22
    Dmarsh22 New Member
    David
    2004 tacoma
    Thank you running board man
  9. Oct 19, 2020 at 4:57 AM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
