throttle body adjustment
Discussion in '1st Gen. Tacomas (1995-2004)' started by montanabay, Sep 2, 2010.
  1. Sep 2, 2010 at 8:46 AM
    montanabay
    montanabay [OP] Active Member
    CA
    2.7L 4WD AUTO
    Hi All,
    So I noticed some slack in my throttle and accelerator cables (see picture 1), I realize there is suppose to be a little, but I took a picture to see what you guys thought. There is enough slack that I can wiggle it and move it up and down without moving the throttle pulley, should I tighten it up so its just enough tension that it doesn't pull on the pulley, yet can be slightly depressed?
    Does the same go for the accelerator pulley?
    Second question on the throttle position actuator, when cold its about 1/2" from the stop screw (see pic 2), when running at idle it doesn't move, when I apply throttle it moves slightly out, but quickly goes back, even with continued throttle. It slowly moves out as the engine warms, is this normal? After the engine is warm and I shut it off, it pops out enough to reach the screw stopper (see pic 3). Is this suppose to be what happens? What exactly does this do for the engine?
    Thanks for the help!
    Josh
  2. Sep 2, 2010 at 8:48 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    PIcs not showing up
  3. Sep 2, 2010 at 8:50 AM
    montanabay
    CA
    2.7L 4WD AUTO
    thanks, fixed
  4. Sep 2, 2010 at 9:05 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That looks about like what my 2.7 had. Look into the TB and make sure its opening up all the way when someone pushes the accelerator down. Do this when its not running.
  5. Sep 2, 2010 at 9:06 AM
    scocar
    scocar hypotenoper
    I have a 3.4, but I noticed the same thing on mine. I didn't investigate its behavior while running like you did, but it is running perfectly, so I figured it was normal and haven't worried about it.
    TRVLR500 likes this.
  6. Sep 2, 2010 at 9:28 AM
    montanabay
    CA
    2.7L 4WD AUTO
    well in the last 6months I have been driving exclusively in ESC, which I think has made me drive a little more aggressive.
    About 3 months ago I did a flush on the ATF, put in a new filter, and added a mega inline ATF filter after the radiator.
    She was driving awesome until last week, when we had the first 100 degree weather all summer out here, normally 70s, and I noticed that the engine was reving higher and shifting a little later, the shifts are still smooth though. The other day on a hill I came close to a full stop on coast, no brake, looking for a parking spot, and it shifted down and up really quick in succession, it never has done this before. I also noticed that when accelerating, it doesn't shift as quick as it used to.
    At first I thought it was a transmission problem, but I found some trouble shooting links that said it could be the TB or TBS needing adjustment, so thats what made me look at the TB.
    its a 1996 2.7L with 180,000 on it, in my knowledge these cables have never been adjusted. Looking at the threading and nut position, looks like it has never been moved.
    I just shortened the throttle 1/4" and accelerator too, haven't test drove it yet, I'll report the results!
    In the mean time, I'm still curious about that vacuum actuator it what it does and how to make sure its working properly....
    Thanks!
    Josh
  7. Sep 3, 2010 at 10:38 PM
    jesus
    jesus Well-Known Member
    jesus
    bakersfield
    K&N ram intake & doug exs.
    cool josh let us kow how it works out
  8. Sep 12, 2010 at 9:52 AM
    montanabay
    CA
    2.7L 4WD AUTO
    Hi All,
    So heres the update. I took the slack out of both the accelerator and throttle.
    Observations:
    1) The truck definitely reacts quicker to the gas peddle
    2) The shifting "problem" seems to be better, as the engine RPMs seem to be more inline with the shift points.
    Thoughts:
    When I did the DIY flush and filter change, the truck was at 175,000. About 40,000 miles before I had Firestone do a drain and fill, but they did not do a flush or drop the pan, so I'm thinking that there was a lot of junk and old ATF in the system when I did the DIY flush. When I did the flush, I did a couple drain and fills of Dex III, the idea was to use cheaper ATF to help dilute the old ATF and clean it up before flushing with Dex VI. My Dex VI flush consisted of dropping the pan, new filter, and adding a megafine inline filter after the radiator. I flushed with ~16qt of Valvoline Dex VI (was on sale for $4!).
    What I'm thinking is that the truck shifted "flawlessly" for the first three months was because the new ATF and filters had yet to really clean my system. I'm thinking that after three months the Dex VI probably help remove a lot of varnish and junk from through the system and the hopefully the megafine was filtering it out.
    So now, the sharper, more noticeable shifts are simply a healthy tranny, that is engaging efficiently, making it more noticeable to me, since I been paying more attention to performance while driving in ETC exclusively. The engine revs was 90% likely due to the lose throttle and accelerator cables.
    So now I have a quick, strong shifting truck, which I thought was a problem, since it was different than before, but I'm thinking this is the way it SHOULD be shifting?
    Anyone else have some thoughts, verification to my observation?
    Thanks!
    Josh
    CS_AR likes this.
  9. Dec 23, 2019 at 11:30 PM
    Tacoma1997White4x4
    Tacoma1997White4x4 America First
    West Covina, California
    1997 white 4x4 auto 4cylinder Singlecab, 2001 auto rwd 2.4l single cab flatbed
    Km3’s 31’s,Lift,Sliders,rear ARB air locker,on board air, armor, hi shell
    How did you adjust? is there a link? haynes manyal? thx
  10. Dec 24, 2019 at 12:50 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    You might wait for sometime to get a response a 9 year old thread .
    Most times you just adjust to take the slackout
  11. Dec 24, 2019 at 12:57 AM
    TWJLee
    TWJLee Well-Known Member
    Jay
    Midwest
    2001 Tacoma 4X4 2.7 5spd access cab 2020 Tundra DC LmTD 2020 F150 5.0
    2020 Tundra GFC 33’s Borla Pro XS FOX 2.0 2020 F150 33’s Magnaflow FOX 2.0 2001 Tacoma 4x4 2.7 5spd access cab new frame 217k 2” lifted Always for sale.
  12. Dec 24, 2019 at 8:36 PM
    Tacoma1997White4x4
    Thanks! But I read on here on he forums many saying, do not touch and it doesnt matter if i adjust the ecm will go back to rpm from before......my rpms when warm is 630rpm and theottle doesnt feel right on, I just purchased truck 4 months ago and previous owner didnt seem to care about the truck so idk if he mightve took out theottle and left it wrong, thx again
  13. Dec 24, 2019 at 8:37 PM
    Tacoma1997White4x4
    Just realized it was 9 years ago lol
  14. Dec 24, 2019 at 10:37 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I adjusted the slack out of my throttle cable on my 2004 2.7 about 4 years ago and it made no difference at all. I just leave everything alone unless I really have a problem. Which I have never had.
  15. Dec 25, 2019 at 2:17 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I can`t recall what year drive by wire started and the throttle cable was eliminated
  16. Dec 25, 2019 at 6:27 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    I would be happy with nice crisp shifts. People pay $,$$$.$$ to get that feeling. I'm not sure if you year model supports the tran temp monitoring. I've found that monitoring the tran temp is good information to know while driving. I'm using Scanguage to monitor it. There may be other phone apps that provide that monitoring as well.
    https://www.levelten.com/Level_10_Toyota_PTS_Bulletproof_Transmission_p/toy-ja1800-5000p.htm
  17. Dec 25, 2019 at 3:32 PM
    Glamisman
    Glamisman Well-Known Member
    there is a secification for adjusting the transmission/throttle pressure cable. As you have noticed the shifts are firmer. I believe that Timmah! has a video on adjusting that cable.
    The vacuum pot is there to slow down the closing of the throttle plate to eliminate a high vacuum situation and exhaust backfire. Its an emmission thing.
  18. Dec 25, 2019 at 9:29 PM
    Tacoma1997White4x4
    link?
