throttle body cleaning question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ahlerscurtis, Mar 19, 2021.
  1. Mar 19, 2021 at 7:18 AM
    ahlerscurtis
    ahlerscurtis [OP] Well-Known Member
    2019 Quicksand TRD OR DCLB
    Dealer said my throttle body is dirty. instead of paying $160 for them to do it, I'm going to give it a try.
    I've read a couple write ups and seams straight forward.
    My question is: Can I push and open the butterfly value if the I the throttle body disconnected? Will pushing on the value cases the gears/motor to get off track? Or should I leave it alone and just clean around it. Thanks
  2. Mar 19, 2021 at 7:23 AM
    Tacospike
    Two Trucks
    I have some cleaner on order.
    I was planning on leaving it connected and propping it open and toothbrush method.
    also pulling the mass airflow sensor as well and cleaning it
    tonered likes this.
  3. Mar 19, 2021 at 7:26 AM
    AZ_Tumbleweed
    AZ_Tumbleweed Well-Known Member
    Wilmington, NC
    2020 TRD OR DCSB Cement 4x4 AT
    Post back and let us know if its actually dirty when you go to clean it or if the dealer was trying to make a quick buck. They typically love recommending additional maintenance thats not part of the vehicles routine maintenance guide. if you don't do it or other suggested maintenance at least it wont void your warranty either per the manual:
    "Dealer-Recommended Maintenance:
    Your dealer may recommend more frequent maintenance intervals or more maintenance services than those listed in the scheduled maintenance log. These additional services are not required to maintain your warranty coverage. Ask your dealer to explain any recommended maintenance not in"
    Junkhead and tonered like this.
  4. Mar 19, 2021 at 7:26 AM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    Use MAF cleaner on the MAF sensor if this vehicle has one and then for the throttle body spray the shit out of it with cleaner and yes you can open the valve it wont hurt it
  5. Mar 19, 2021 at 9:29 AM
    gearcruncher
    Canadain bumper technician
    Any of these cleaning services should be done with the battery terminals removed .
    You can manipulate the throttle body in any direction with the battery posts removed .
    Most use a Techstream to reset the idle position but can be done just by removing the battery terminals . Its going to allow your ecm to quickly adjust for the new idle position instead of the truck stalling for at least a day . When crap builds up in the throttle body , your ecm compensates for this . Now that your throttle body is clean , The ecm in your truck has to learn a new idle format . If you remove the terminals , the ecm thinks you have a new throttle body with zero contamination . The result ... your truck will idle
    Will also save the OP from posting that his truck runs rough and stalls after throttle body cleaning .
    An old toothbrush works well with throttle body cleaner . The toothbrush is gentle on the anodized coating
    hiPSI and tonered like this.
  6. Mar 19, 2021 at 9:44 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Please, Please, Please take pictures of the cold side of the throttle body and the breather hose on the side of the intake hose for any oil coming into that side of the intake system, and post them here.
    Thank you!
    Junkhead likes this.
  7. Mar 19, 2021 at 9:44 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I believe you have to reset it in Techstream; "Reset Idle Learn", or some such.
  8. Mar 19, 2021 at 9:54 AM
    Sauer Taco
    Sauer Taco Well-Known Member
    Paul
    Finksburg MD
    16 TRD Sport DCLB BBP
    This and the MAF sensor cleaning was recommended by the dealer for my wife's 2018 Rav (50K miles +/-)...dealer wanted well over $300. Called the local mechanic, he did both for under $150. Came back saying they really weren't that dirty. But, from what I understand not cleaning them on a regular basis can result in the potential for problems later on.
  9. Mar 19, 2021 at 9:57 AM
    MauiBrian
    MauiBrian Kapalua fun
    Brian
    Maui
    2018 SR lightly modded
    This ^^^
    Many modern scan tools have this function, I have a Launch unit that does this.
    To the OP, most of these services are profit centers for the dealer. Unless you're having issues I would decline any dealer add-ons.
    Just my $0.02...
  10. Mar 19, 2021 at 11:27 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I use to run sea foam per directions through my throttle body and intake runners for the 4.7 tundra...kept it spotless, plus it cleaned the valves. Smoked like hell through. Dealer wanted $120 at the time for this service. Easiest thing to do.
  11. Oct 23, 2021 at 8:24 AM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    Check out some YouTube videos from the Car Care Nut. He indicates the later Tacoma’s don’t have this issue.
    https://youtu.be/ei5yC4IdDhs
  12. Oct 23, 2021 at 8:27 AM
    mquibble
    Michael
    2021 TacomaTRD Pro
    https://youtu.be/3B-a8WJtd8w
    walleye_slayer likes this.
  13. Oct 23, 2021 at 8:29 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    No.....don't use brake cleaner.
    Use MAF cleaner on the MAF, no toothbrush just spray.
    Use Throttle Body cleaner on the Throttle Body. Be gentle with the butterfly, it will move with some small effort, tooth brush is acceptable.
    Disconnect the Neg terminal on the Battery and you could pull the wire harness connectors to the MAF and Throttle Body.
  14. Oct 23, 2021 at 9:01 AM
    Knute
    Think about it.
    Where would you think the Throttle Body connector should be located..........?
    Sorry, I'm not in a position to say what a dealer does. I did not remove the throttle body on my truck to clean it.
  15. Oct 23, 2021 at 9:02 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    MAF is the upper photo in your post, on the intake pipe between the air box and TB.
    nightcrawler likes this.
  16. Oct 23, 2021 at 9:04 AM
    Knute
    Spoiler.
  17. Jun 30, 2024 at 12:50 PM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Falken Rubitrek AT 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    I just cleaned my throttlebody and my MAF sensor with a CRC kit I got at Walmart. I did not disconnect the battery cable. Removed the two small screws on the MAF sensor and I sprayed it out really good with the MAF cleaner can wiped it down and put it back into the air cleaner housing. I gently opened the butterfly in throttle body and used an old toothbrush and cleaner (sprayed cleaner inside opening) and a shop towel on both the upper and lower sides of the throttle body opening and put it back together. Hard and slow to start and sluggish at first and slow to turn over, but seems that once the cleaner residue was out of the system everything is running great. Let it idle for about five minutes and then took it for a test drive. My Toyota mechanic friend told me to be gentle with slow movements with the throttle body butterfly and not to overdo it. He said everything will eventually straighten out with the way the system works after driving it a few miles. All seems to be good! Not sure about the requirement for disconnecting the battery (I didn’t bother because I read this post as after I had already done the cleaning). I’m no auto mechanic. Anybody should be able to do this cleaning and save some money, no need to take it to the dealership.
    baboltin and mquibble like this.
