Throttle body cleaning
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Greg-tacoma, Jun 29, 2025.
  1. Jun 29, 2025 at 8:04 AM
    Greg-tacoma
    Greg-tacoma [OP] Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    I have watched several videos and some have you remove the body while others just spray cleaner and wipe. Should I remove it, clean it and replace gasket? Or just spray and wipe? Thoughts
  2. Jun 29, 2025 at 9:48 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Whatever is easiest, I've done it both ways depending on access and how hard it is to remove.
    Typically don't have to replace the gasket unless it's degraded/flat.
  3. Jun 29, 2025 at 10:53 AM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I removed mine. Can’t do key on engine off and putting a stick on the gas pedal to leave the flap open. It’s only 4 12 mm nuts I think after removing the air boot.
  4. Jun 29, 2025 at 10:57 AM
    Greg-tacoma
    Greg
    2016 Black 4cyl 4wd
  5. Jun 29, 2025 at 10:58 AM
    Bishop84
    Bishop84 Well-Known Member
    Remove is best, and I've re-used them often, they don't really crush and wear.
    RustyGreen and STEELeR43 like this.
  6. Jun 29, 2025 at 4:15 PM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Why can’t you slowly push the butterfly open, wipe and put it all back together?
  7. Jun 29, 2025 at 4:32 PM
    1gtacomeat
    1gtacomeat New Member
    97 tacoma 2x4 bench
    Sdyota drop kit, qa1 coil over, tri spoke mustang 17”, rc forward facing plenum, egr delete, acc carpet kit in red, cigarette to usb upgrade.
    I personally removed mine recently, man did it need it with 297k.
    I would certainly take it off for two reasons. One, There are small channels that run down to the iacv and carb cleaner can carry deposits down with gravity and clog the iacv unit. And two you can remove the iacv unit with a jis philips screw driver or vice grips and clean that unit as well as bench test it with 12v and watch it operate for a peace of mind. dont think about it, that over complicates things. Good luck you got this.
