Throttle Body Gasket mod?. 01 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by oneguyonetaco, Jun 10, 2013.
  1. Jun 10, 2013 at 11:00 AM
    oneguyonetaco
    oneguyonetaco [OP] Member
    James
    Eden Prairie, MN
    01 Tacoma DLX
    Airaid Jr Intake w/ Filter. Electric Fan. Modified Stock Throttle Body Gasket. Royal Purple Oil. NGK Iridium Plugs. Grey Wire Mod.
    I pulled my intake and throttle body and cleaned them the other day. When I pulled my throttle body I noticed the Stock metal gasket covered a good portion of the hole. I decided I would grind the metal gasket to a complete circle and it seemed to really help.
    Now I have looked on the forum for anything like it but found nothing. Does anyone do this to theirs?
  2. Jun 10, 2013 at 11:02 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    1st Gen problems :rolleyes:
    In all seriousness though, good idea!
  3. Jun 10, 2013 at 11:03 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
  4. Jun 10, 2013 at 11:08 AM
    oneguyonetaco
    James
    Eden Prairie, MN
    01 Tacoma DLX
    I like taking things apart one time if possible. It was there I did it. Just thought I would share.
  5. Jun 11, 2013 at 4:22 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    I cut mine out and didn't notice a difference other than the intake whistles more. Which maybe why its there in the first place.
  6. Jun 11, 2013 at 8:29 PM
    Madjik_Man
    Colorado Front Range
    They sell "O" gaskets. I think they're for the supercharged motors.
    I think they're $4 at the dealer.
    Scroll 3/4 of the way down. http://www.top4runners.com/ja/cleantb.html
    Edit: nevermind... I should always read the thread before posting.
  7. Jun 12, 2013 at 6:18 AM
    oneguyonetaco
    James
    Eden Prairie, MN
    01 Tacoma DLX
    I also have a sheet of gasket I could cut to size. I could also spend $4 on a "TRD" gasket and wait a week for it to get to my house but I didn't. The point is , I didn't know it was there as do some others like myself. My point in this thread was to allow people like me to know these things. There is no thread that I found talking about this gasket. As you can see in the pic of my truck, I like to leave my truck as stock as possible. This is a great thread in my opinion because its so easy to miss and it really helped my throttle response.
    BTW I love TW.
  8. Jun 12, 2013 at 1:28 PM
    Madjik_Man
    Check the slack in your throttle cable also. When I did my MAF, TB cleaning and plugs/wires, it was the tightening of the slack in the throttle cable that made the world of difference to me.
    Welcome to TW, btw
  9. Jun 12, 2013 at 1:39 PM
    scocar
    scocar hypotenoper
    Yeah this has come up before, and people have swapped in the non-D-shaped supercharger gasket and not noticed a difference.
    I would not change the gasket material, and would stick with the OEM metal crush gasket, which is very thin and not reusable. You don't want a leak there that could screw up your air-fuel ratio.
  10. Jun 12, 2013 at 3:55 PM
    oneguyonetaco
    James
    Eden Prairie, MN
    01 Tacoma DLX
    Oh ya, I pulled the slack out on the cables. All the little things ad up in my opinion. My truck gets pretty damn good gas mileage.
    Anyways, I personally am glad I did that to my gasket. A: It was fun B: Yes, It helped my throttle response, No Doubt. Mostly from a stop to go. Unfortunately I wish I could say I gained Ponies but I didn't, lol.
  11. Jun 12, 2013 at 5:05 PM
    Madjik_Man
    I can get 340-350 miles per tank on my 31s
    :anonymous:
  12. Mar 13, 2014 at 12:13 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    How in the world do you get that!!? :eek:
  13. Mar 13, 2014 at 1:02 PM
    scocar
    scocar hypotenoper
    That metal TB gasket is not reusable. It is a crush gasket with a small impressed ridge around the circumference. If you want to do this, just the the supercharger gasket .
    IIRC, no one has achieved a demonstrable benefit (dyno data) from doing this.
  14. Mar 13, 2014 at 1:04 PM
    scocar
    scocar hypotenoper
    Downhill both ways in 5th at 45 mph on non-ethanol gas and 100 psi in tires and interior stripped out and no battery.
    You dick. I need to change my fuel filter and then run several gallons of Techron through.
  15. Mar 13, 2014 at 4:15 PM
    smmarine
    Melbourne FL
    ^:rofl: that last comment
  16. Mar 13, 2014 at 5:56 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    I did it for the lols... No difference what so ever
  17. Mar 13, 2014 at 7:24 PM
    trdtoy
    trdtoy Well-Known Member
    North Carolina
    02 sr5 4x4 auto v6 turbo (sold)
    Turbo with supporting mods and tranny to hold power.
    Not much is to be had with this mod on a na setup and likely more for sound reduction. With forced induction this will become more of a restriction and more power can be made with the "o" gasket vs the "d" gasket.
  18. Mar 5, 2015 at 3:50 PM
    Canyon Jeff
    Canyon Jeff Well-Known Member
    Jeff
    Southeast Utah
    98 Tacoma V6 3.4, TRD 4x4 5-speed 100k miles
    i dunno. I've never run my tank to the very bottom, but when the needle hits the 1/4 tank notch, I am usually around 260 or 270 miles. So I think I could go over 300 miles on a full tank.
    also rollin on 31s
