Throttle body gasket
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco Phil, Dec 18, 2023.
  1. Dec 18, 2023 at 7:31 AM
    Taco Phil
    Taco Phil [OP] Taco Phil
    Galveston, Texas
    04 2.7 3RZFE Reg Cab 4X4
    Beautifully stock
    Changing out the IAC. Do I need to change the throttlebody gasket? Thanks for sharing your wisdom.
  2. Dec 18, 2023 at 7:49 AM
    Indyteecee
    Indyteecee bad at building Toyotas, good at breaking stuff
    Wyatt
    Utah
    04 Tacoma Double Cab TRD
    It’s good practice, but as long as it’s not broken it’s not a huge deal.
    Taco Phil[OP] likes this.
  3. Dec 18, 2023 at 7:55 AM
    Taco Phil
    Galveston, Texas
    Beautifully stock
    Thank you sir!
  4. Dec 18, 2023 at 8:26 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    there's two kinds...
    the black plastic/rubberized one lasts several cycles or reuse.
    The paper aftermarket ones, are made out of gasket material, do not.
    Its best to have an extra one of these on hands anyways.
    I keep an extra IAC one on hand too......you never know.
  5. Dec 18, 2023 at 8:32 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Yes- you can reuse the gasket. However, it's been my experience that it's difficult to get the previously used gasket to seat without being pinched out of place. I have successfully used a pick (from a hook and pick set) to nudge the gasket in place while tightening the IAC into place. Did that a few times, and then I just ordered a few of the gaskets to have on hand for future cleanings. The new gaskets compared to the used gaskets haven't "expanded" (that the best term I can use to describe it).
  6. Dec 18, 2023 at 8:58 AM
    Taco Phil
    Galveston, Texas
    Beautifully stock
    You guys rock. Much aloha.
  7. Dec 18, 2023 at 9:15 AM
    Taco Phil
    Galveston, Texas
    Beautifully stock
    Wish me luck! First time doing this. Experience level is 7
