Throttle body, is this an issue?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Larzzzz, May 6, 2019.
  1. May 7, 2019 at 2:23 PM
    Larzzzz
    Larzzzz [OP] Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Don't know. I don't have the time to pull it apart right now either.
  2. May 7, 2019 at 7:52 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    the other 2 are redundant feedback sensors, motor is the pink and blue wires. Measure between pins 1 and 2, should get 0.3 to 100 ohms according to the FSM.
    Larzzzz[QUOTED][OP] likes this.
  3. May 8, 2019 at 3:39 AM
    Larzzzz
    Larry
    MA
    Thanks. Sadly i won't have the time to check it out today though. Kids will eat up every free second. Wouldn't give it up for anything though.:thumbsup:
    6 gearT444E likes this.
  4. May 8, 2019 at 3:50 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    What did you clean the throttle body and MAF with?
  5. May 8, 2019 at 3:52 AM
    Larzzzz
    Larry
    MA
    Crc throttle body cleaner and crc maf cleaner. And no, i didn't touch the bulb on the maf. Didn't even use the tube for the nozzle.
  6. May 8, 2019 at 3:53 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Was the butterfly valve stuck? Or just not going past ~20% open?
  7. May 8, 2019 at 3:59 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Maybe you need to relearn the TPS. Turn the key in. Press and hold the pedal to the floor. Wait 5 seconds and then off. Wait 2 seconds and repeat 3x. Then turn the key off, then start it up. Might take a try to two
  8. May 8, 2019 at 4:00 AM
    Larzzzz
    Larry
    MA
    It did not appear to be stuck to me. The throttle body was plugged in and sitting on the fan shroud when I noticed this.
    Basically I'm wondering if that because the air filter housing and MAF sensor were removed from the system with the key on and the engine off when I push the throttle to the floor it did not open up any more than maaaybe 20%.
  9. May 8, 2019 at 4:26 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    If you unplugged them and the key was on the TPS definitely needs to be relearned
  10. May 8, 2019 at 12:01 PM
    Larzzzz
    Larry
    MA
    The MAF was the only thing disconnected with the key on.
    I'll try the tps reset.
    @Lawfarin Larry, have you seen our brother Darryl?
    :rofl::rofl::rofl::rofl:
  11. May 8, 2019 at 12:33 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Lol, that show started before I was born. But I heard about it. I know a Darryl that could probably play the part.
    Keep me posted on the relearn!
  12. May 9, 2019 at 3:18 PM
    Larzzzz
    Larry
    MA
    @Lawfarin that tps relearn seems to have done something. I haven't felt that flat spot as it were and the throttle response seems to be better.
    Thanks.
    b_r_o likes this.
