throttle body question
Discussion in '1st Gen. Tacomas (1995-2004)' started by anthony250f, Jun 9, 2014.
  1. Jun 9, 2014 at 8:55 PM
    anthony250f
    anthony250f [OP] Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    will a throttle body off a auto work in a manual?? my butterfly valve isnt closing all the way and im pretty sure thats why its idling at 2K rpms (unless i manually close it)
    any ideas?? i can only seem to find used ones for a AT
  2. Jun 10, 2014 at 5:22 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    Are you asking for the 07 you have listed? If so, you'd better post in the 2nd gen section, just in case.
  3. Jun 10, 2014 at 8:22 AM
    anthony250f
    Anthony
    San Diego, CA
    Ugh it's for a first gen actually.1997 3.4 5 speed ...fucking idiot
    T200? What the fuck
  4. Jun 10, 2014 at 8:31 AM
    anthony250f
    Anthony
    San Diego, CA
    i sold my 07 and this is posted in the right section...so you neg me? you're a fucking idiot and the "tough act" isnt doing shit for you.
    there i re did the truck bio...happy? no go try to be cool somewhere else.
  5. Jun 10, 2014 at 8:35 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    TBs should all be the same regardless of AT or MT, just make sure to get one from the same year or series (03-04 would definitely not work)
  6. Jun 10, 2014 at 8:35 AM
    scocar
    scocar Patron of the Farts
    E-penises are blocking their vision.
    I don't see why it wouldn't. I'd just take detailed pics of both and compare features/ports.
    Is a TB R&R really the answer though? Might be a TPS, they are sorta notorious. Not sure what the cost difference is for a new TPS vs a used TB.
  7. Jun 10, 2014 at 8:46 AM
    anthony250f
    Anthony
    San Diego, CA
    so what i have found out is that the autos are different because they have a transmission kick down cable, and the manuals dont. Im going to clean the tb today. Already cleaned the iac
  8. Jun 10, 2014 at 10:00 AM
    scocar
    The intake crush gasket is not reusable, suggest getting a new one to prevent potential issues.
    You can get the IAC coolant gasket too, that is rubber and reusable I believe, but I just put a new one in since I had it apart.
    Mind you don't get the little coolant hose under the TB kinked during reinstallation. I had to get mine on, then adjust the hose into correct position. Not a lot of play under there.
    Kinked after intall
    unkinked
    Ellendejefferes likes this.
  9. Jun 10, 2014 at 10:16 AM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Did you check all your vacuum hoses going to the throttle body? Did you check cable for play? The tps is different than the iac also. The tps is the throttle position sensor, the iac is idle air control. Make sure you use the proper cleaner for tb. Aerosol carb cleaner is what I have used. Got to be 02 and cat friendly.
  10. Jun 10, 2014 at 10:59 AM
    anthony250f
    Anthony
    San Diego, CA
    No problem man....but yes I joined the 1st gen crew
    Throttle body is clean inside...pulled the battery so well see if that does anything...previous owner had a spring rigged up...used carb cleaner, haven't checked the tps
  11. Jun 10, 2014 at 5:15 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Did you try adjusting the throttle cable?
  12. Jun 10, 2014 at 5:29 PM
    anthony250f
    Anthony
    San Diego, CA
    Yes...it did it even when the cable isn't attached ...not really sure what to do
  13. Jun 10, 2014 at 10:36 PM
    scocar
    Here (attached) are some basic inspection points that might indicate if it is the TB versus elsewhere.
    edit: this is from the 2003 FSM, but it is for the non-ETCSi TB
    edit: and includes testing of TPS
  14. Jun 11, 2014 at 6:56 AM
    Madjik_Man
    Colorado Front Range
  15. Jun 11, 2014 at 6:59 AM
    Madjik_Man
    My idle was way high like yours also... never kicked down. Messing with the butterfly valve, throttle cable, etc didn't have any effect.
    It was a faulty TPS.
    Replaced it and all was good.
  16. Jun 11, 2014 at 7:10 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I haven't seen the inside of the TPS but if it was replaced and it didn't have the right metal attachment it could be off. This was what I had to look out for when I swapped a newer TB for my older version on my old 22RE, had to swap the tps attachment on the inside to make it idle right. Just throwing it out there.
  17. Jun 11, 2014 at 7:17 AM
    Andy.G
    Andy
    Virginia
    I need to save this, could be used often!!haha
    What's up Madjic_Man! Like your style.:thumbsup::thumbsup:
  18. Jun 11, 2014 at 9:47 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    this makes no sense
  19. Jun 11, 2014 at 9:56 AM
    anthony250f
    Anthony
    San Diego, CA
    Should I try unplugging the tps while it's idling? Saw it mentioned on ttora
  20. Jun 14, 2014 at 6:09 AM
    Nutzo333
    Nutzo333 FreakShow333
    Cory
    Canada
    Lifted 06 SR5
    6" Fabtech Lift, 315/70 r17 Duratracs, TRD Cold Air Intake MBRP stainless with duel side exit rear exhaust
    Did you solve the issue? I just cleaned my whole intake system and I have an identical issue. Idles around 2000, but i noticed if i unplugged the TB, it idled back down to 700 ish
