Throttle Body Spacer and Cold Air Intake
Discussion in '1st Gen. Tacomas (1995-2004)' started by DTaCo, Nov 12, 2009.
  1. Nov 12, 2009 at 11:07 AM
    DTaCo
    DTaCo [OP] Active Member
    Dylan
    Minnesota
    2003 Tacoma manual 4x4 V6
    6" Drop Bracket Suspension Lift with coil spacers and a 1" body lift. Trailmaster add-a-leaf in in the back with a 3" block.
    I am thinking about adding a throttle body spacer and cold air intake to help improve performance and gas milage (I am currently averaging 15mpg). Let me know your thoughts.
  2. Nov 12, 2009 at 11:53 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
    TB spacers do nothing. Most "Cold Air Intakes" are actually Hot air intakes, as they suck air from the engine bay, as opposed to the OEM location which is in the fender. Best way to get better MPG, is make sure your vehicle is in a propper state of tune, tires are at correct psi, and watch your right foot.
  3. Nov 18, 2009 at 7:31 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Do the deck plate mod instead of a CAI. It's more effective and only costs about $10. Do a search on it, it's everywhere on here. I'm hoping to get mine done sometime soon when I get some time.
  4. Nov 19, 2009 at 9:02 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    What size tires you running on 6" lift and 1" blocks? 35's?
  5. Nov 19, 2009 at 9:06 AM
    DTaCo
    Dylan
    Minnesota
    Yeah I have 35x14.5's on, if you went with a narrower tire you could get 36's on.
  6. Nov 19, 2009 at 9:08 AM
    AZCOMA
    AZCOMA where can't I go?
    Kacey
    Laveen
    05 Preunner sr5
    2.5 saw co's, n-fab bed cage rear tire mount,new head unit and 10"sub,285/75/16 nittos on M/T wheels,H.I.D.'s...The next mod is T.C. long travle kit,Deavers and glass all the way around.
    what is a deck plate?
  7. Nov 19, 2009 at 9:10 AM
    98tacoma27
    Ben
    Not Beech Creek
    Commonly used for access to compartments on boats. They are water tight when installed correctly. One is installed in the factory air box on the first gens.
  8. Nov 19, 2009 at 9:18 AM
    sirsaechao
    Tim
    CA
    Could that be why your mpg is so low? :p
  9. Nov 19, 2009 at 9:22 AM
    DTaCo
    Dylan
    Minnesota
