Throttle Body Spacer: Is it worth it?
Discussion in '1st Gen. Tacomas (1995-2004)' started by goldentaco03, Jun 13, 2015.
  1. Jun 16, 2015 at 3:26 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I did the Deckplate mod. on my 04 3.4 and it was super easy. Plus if you want to go out where water might enter the air box you can screw the lid back onto the hole you cut into the housing. It's just like an air intake but costs $20 and you can open or close the air flow depending on where you're taking your truck. I am very happy with it. I put a K&N filter on it and I even took it to get smogged and had no problems other than the smog tech had no idea what he was looking at! 231,000 miles and still going strong. I changed the MAF to since I was cleaning it and noticed a broken element on it. I bought a OEM Denso MAF off of Amazon for $65 vs. O'reilly's or Autozone who wanted $125 for the same part
  2. Jun 16, 2015 at 8:10 PM
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    ICON 3" LIFT, Console Vault, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Undercover SE Tonneau
  3. Jun 17, 2015 at 8:47 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I have yet to see any dyno or scanguage tests that prove any performance increases from these shiny, expensive engine jewels.
    Want to know the best way to increase the power and throttle response in your truck? Keep the air filter changed once a year. Change your spark plugs. Dump some fuel injector cleaner in every oil change and use Top Tier gas. In other words, keep your engine maintained perfectly so that no performance potential is lost due to neglect. Rather than spending $300 on a piece of plastic that is a "cold air intake" when you basically already have a cold air intake by the sheer design of the ones on the Tacoma, instead try to make sure the engine is running in tip top condition before you try to make up what ground you could gain power-wise with a simple tune-up.
    Ninj likes this.
  4. Jun 17, 2015 at 9:52 AM
    Ninj
    Ninj Well-Known Member
    Ninja
    New Hampshire
    2011 Super White TRD Off-road SR5 6 Speed
    URD True Cold Air Intake URD MAF PnP Version (Very easy to install) Full Custom Exhaust 2.5" Stainless Steel Pipe, Doug Thorley Long Tube Ceramic Coated Headers, 2 stock catalytic converters (2 cat deletes), X Pipe, Dual Flowmaster Super 44s, 2 Jones 18 inch stainless steel tips, Full exhaust exits before rear passenger wheel like the SVT Lightning (I have Krisxone’s 09+ ECU adapter so I can go URD Boosted, Tested and working) 3 Inch Ultimate Toyotech lift (Silver Painted Coilovers) with Old Man Emu Leafs (No add-a-leaf here)
    If these gains are so obvious show us a before and after dyno sheet saying that a Throttle body spacer is doing anything other than putting your money into someone else's pocket
  5. Jun 17, 2015 at 9:58 AM
    scocar
    scocar hypotenoper
    The one result you can be assured of is redistribution of wealth.
    P.T. Barnum
  6. Jun 17, 2015 at 2:06 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Stock intake is as "cold air intake" as it gets and most of the so called CAIs are actually the complete opposite of a "cold air" intake. As to the Tb spacer, there actually is some science behind it as far as changing runner lengths in the intake manifold to change the power band, example- going from a low rise manifold to a high rise on a 4bbl carb v8 can move the power band up in rpm a bit, but as I believe was mentioned earlier this is more noticeable on carb. Vehicles over efi. However the minimal difference the spacer makes plus the already really long runners on the Toyota intake manifolds really make it pointless and have little to know effect.
