Throttle body spacer worth it?
Discussion in 'Performance and Tuning' started by m3dragon, Oct 18, 2007.
  1. Oct 18, 2007 at 8:51 AM
    m3dragon
    m3dragon [OP] Well-Known Member
    Sacramento
    Ok Does a 12mm throttle body spacer actual do anything worth while for the $$?
    I have never heard anything about them or anyone actual using one.
    thanks
  2. Oct 18, 2007 at 9:20 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    I have heard that these are junk and a waste of money. :(
  3. Oct 18, 2007 at 9:43 AM
    gdawg25
    gdawg25 Zoom-Zoom
    Victoria, BC
    '08 Mazdaspeed 3
    Don't waste your money.
  4. Oct 19, 2007 at 4:56 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Yeah, of course it works..... as a paperweight.
  5. Oct 20, 2007 at 10:05 PM
    nolanspawn
    nolanspawn Work In Progress
    Layton, Utah
    2011 Tundra Crewmax
    Corsa Exhuast, AFE Intake
    If our intake manifold was made out of aluminum or other metal then there might be a point. Even more so if they made spacers to go between the intake manifold and the heads. Only in that case though of our intake manifold being made of metal. With our intake being plastic, thats the unit you would want to stay cool. Its not going to get as hot and hold heat as much as metal.
  6. Oct 20, 2007 at 10:08 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Waste'o'money is what it should be called
  7. Oct 22, 2007 at 2:03 PM
    m3dragon
    Sacramento
    Danny72 likes this.
  8. Oct 22, 2007 at 2:54 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    his caption is straight from a website...u can tell by the wording. and correct me if i'm wrong people, but wouldnt a tb spacer only work on an engine w/o fuel injection? its basis is for the air/fuel mixture...but no fuel goes in where this spacer is on the 4.0L
    98tacoma27 likes this.
  9. Oct 22, 2007 at 3:37 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    Yeah, those things only work on non-FI'd engines. There's no way that the air can stay swirled thoughout the inake plenum down to the combustion chamber.
  10. Oct 22, 2007 at 5:51 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you got that right!!!
    all throttle body spacers are is basically "snake oil"!!! companies know people will put down money for things that are too good to be true, and im willing to bet the only increase anyone sees with a tb spacer is the "placebo effect"!!!
    in other words..........................spend money on something worthwhile,not something that whistles!!
  11. Oct 22, 2007 at 11:44 PM
    reid
    reid Well-Known Member
    Vancouver BC Canada
    2007 V6 Access Cab
    Magna Flow stainless cat-back, 3" Toytec Lift, 32" Mickey Thompsons
    Perfect timing. I have tried one of these on my 2007 4.0 L Tacoma. As far as I could tell there is no performance change, no negative anyway. But, my fuel economy went up. I dont really get why, but here is what I think.
    After installing the spacer, it took the truck about 15 min. to get used to it and bring the idle down to its original levels. After instalation it tried to idle at 1600rpm.
    What the spacer did was change the powerband. The lower rpms, under 2000-2500, see a bit less power, but over 2500-3000, sees power faster. It seemed to sort of condense the area where I saw the most power. Because during everday driving I keep it under 2500rpm, the truck would not accelerate as fast as before, and therefore use less gas( maybe). But when I do want to go fast, I floor it and it takes off( just as fast as prior to the spacer)
    I dont know if this change was due to the HUGE POWER OF THE SPACER, or more likely moving the sensors about 1.25" away from the intake manifold. But it did do something to my fuel economy. It does something because the idle was originally way off.
    Like I said, this is my best guess. Any other ideas?
    Danny72 likes this.
  12. Oct 25, 2007 at 1:28 PM
    m3dragon
    Sacramento
    That is odd to say the least. I think the "theory" is sound but as we can all agree it seems it is a waste of money for EFI cars.
    Word to anyone reading this thread. DON"T BUY ONE:mad:
  13. Oct 25, 2007 at 4:08 PM
    reid
    Vancouver BC Canada
    2007 V6 Access Cab
    This is the only way I can think of to explain what happened when I put it on. Maybe it is a waste of time to buy one as a performance upgrade, but it did work as a cheap improvement to the MPGs. I would not tell anyone not to buy one. Just dont be fooled into thinking it will increase HP.
  14. Dec 17, 2007 at 9:23 AM
    AZsurfer13
    AZsurfer13 Well-Known Member
    Houston, Texas
    07 Regular Cab Tacoma
    Total Chaos 3" Coil Over and Control Arms, 15" American Racing Mojave's, 31" BFG A/T, Doug Thorley Ceramic Coated Header, Magnaflow Cat Back Exhaust, AFE Stage 2 Cold Air Intake, 20% Tint. (All work done by SDHQ Offroad, www.sdhqoffroad.com)
    True, most of the new TB's dont do much, but that is because most of them out there for the Tacoma's are generic. AFE is coming out with a line of them Mid January. From what I hear they are supposed to be awesome! I will be getting one for my truck for sure.:D
  15. Aug 9, 2012 at 9:37 PM
    YotaKid62
    YotaKid62 Dirty mall crawler
    Forrest
    North Dakota
    00 Tacoma TRD Sr5 5 speed
    Grey Wire Locker Mod, 3" coil spacers & custom leaf packs, 2" BL, Skyjacker rear nitro shocks, Monroe front gas shocks; 15" eclipse sub & 1400 watt visonik amp with Kenwood stereo, Billet Petals, Black Aries series Grille guard, ebay baja lights (unsure of brand)
    Wow this is one OLD ASS thread, anyone know if this has changed any? If there a any 'good' tb spacers now?
  16. Aug 10, 2012 at 6:50 AM
    YotaKid62
    Forrest
    North Dakota
    Ok, thanks for the clarity guys, now what about electric supercharger fans? Are those a waste of money too?
  17. Aug 10, 2012 at 6:56 AM
    The_Hodge
    SC
  18. Aug 10, 2012 at 7:02 AM
    YotaKid62
    Forrest
    North Dakota
    So basically theres no way to get significant hp increase other than a (real) supercharger?
  19. Aug 10, 2012 at 7:08 AM
    98tacoma27
    Ben
    Not Beech Creek
  20. Aug 10, 2012 at 5:58 PM
    YotaKid62
    Forrest
    North Dakota
    ....shit. well at least i can go for imprpving mpgs without breaking the bank and have a slow pickup that get decent mileage lol.
