Throttle Body Spacer
Discussion in 'Performance and Tuning' started by reddsoxy, Jul 16, 2011.
  1. Jul 16, 2011 at 6:21 AM
    reddsoxy
    reddsoxy [OP] Member
    Fayetteville, NC
    2012 TRD Extended
    K&N Air Filter, Leer Cap, Westin Nerf Bars, Westin Bull Bar, Jerry Can x2, Bed Lights, Magnaflow Offroad Pro Series
    I don't have my 'yoda yet but I am already trying to come up with a list of things I want to do to it once I have it in my garage. I have been looking around at various parts and such and was curious if anyone as any experience they would like to share regarding the use of a Throttle Body Spacer... are they worth time time/money? If so, what brand would you recommend?
  2. Jul 16, 2011 at 6:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    They dont work. All they do is make a wistle sound when you get on it.
  3. Jul 16, 2011 at 6:27 AM
    bcb97
    bcb97 Well-Known Member
    The only performance upgrade on a taco worth anything is the supercharger.
  4. Jul 16, 2011 at 6:30 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    what they said.... :D
  5. Jul 16, 2011 at 6:36 AM
    reddsoxy
    Fayetteville, NC
    2012 TRD Extended
    Thank you very much... no throttle body spacer for me.
  6. Jul 16, 2011 at 7:05 AM
    acdronin
    acdronin Well-Known Member
    I would agree that the biggest bang for your buck is the supercharger, it is also the one item that is made specifically for this engine and computer (ECU). BUT, there are other things you can do to this truck such as a CAI (cold air intake) and bolt on cat-back exhaust. The are two issues with these mods though, one, that aftermarket companies make all these boasts about HP and torque claims that frankly don't make a whole lot of difference until you get higher up in the RPM range of the engine, second, like in the case of the CAI, because you are modifying the characteristics of the airflow to the engine, you will confuse the MAF sensor (Mass airflow sensor), and the ECU, this causes the ECU to dump too much fuel into the engine and it kills your MPG's, a company called URD makes a gizmo called a MAF Calibrator which has to be soldered into the ECU harness (the make a plug and play harness but it costs more than the calibrator), that corrects the data from the sensor and largely fixes this issue. These three mods will set you back around 1200-1300 bucks.
    My point is this, these engines are detuned from the factory and there are things that will make a difference but you want to be realistic with yourself and your wallet. It's a truck, if you want to go that fast, buy a hot-rod. In my case, I did the CAI and the cat-back and eventually (through this site), found the MAF Calibrator and put that is, it was trail and error for me and a little frustrating to boot, but is my truck faster? You bet, it will dust any stock Taco no problem, the throttle response is more immediate and above 3000 PRM it pulls like crazy. My advice is that if you really want to make this thing haull ass, the supercharger is the way to go, if you don't have that kind of cash to dump into your truck you can still make it faster, just be realistic about your goals and understand you are getting into screwing with your sensor data and must be taken into consideration.
  7. Jul 16, 2011 at 7:07 AM
    98tacoma27
    Ben
    Not Beech Creek
    When you stand on them, or sit?
  8. Jul 16, 2011 at 7:09 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    don't you think toyota would have put the spacer in there theirself if they knew such a small item would make such an improvement?:notsure:
    That should end it right there. :thumbsup:
  9. Jul 16, 2011 at 7:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Stand. When you sit on them, the tone is more twards the lower end....
  10. Jul 16, 2011 at 7:12 AM
    98tacoma27
    Ben
    Not Beech Creek
    :rimshot:
  11. Jul 20, 2011 at 4:53 PM
    Muscles
    Muscles Well-Known Member
    Kyle
    San Diego
    05 PreRunner TRD
    K&N Air Intake
    I think the whistle sounds cool haha and its only like 100 bucks or something , if you have the money why not. It doesnt do anything performance wise tho
  12. Jul 27, 2011 at 9:54 AM
    Rashnu
    Rashnu Well-Known Member
    '16 T4R TEP
    Stock
    Don't waste your money
  13. Jul 27, 2011 at 10:00 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
