Throttle Body Spacer?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wreckless_71, May 18, 2010.
  1. May 18, 2010 at 9:27 AM
    Wreckless_71
    Wreckless_71 [OP] WRECKLESS for Life...
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    3" Lift via OME 881's, Bilstein 5100's, Dakar OME 3" leaf packs, MBRP custom exhaust, HID headlights, CB, Canopy, aluminum wheels, upgraded sound system, full set of studded snow tires and wheels, auxilary lighting, more to come.
    Anyone done one and had any significant gains? I hear mixed opinions on them... I already have exhaust and deckplate done with a drop in high flow filter so the next thing to do would be T.B.S. or a header... I lean toward the gimic side with the TBS...
  2. May 18, 2010 at 9:29 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
  3. May 18, 2010 at 9:32 AM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    ill save you the trouble. Its useless. makes a whistle. that6s it
  4. May 18, 2010 at 9:33 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    x2, honestly how much of a diff can it make, your truck is still gonna get the same amount of air going in to mix with the gas.
  5. May 18, 2010 at 9:44 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    But it swirls the air causing turbulance and atomizes it better....:p haha tbs are a fucking waste of bad engineering and time for fuel injected engines
  6. May 18, 2010 at 9:52 AM
    Wreckless_71
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    Yeah that's pretty much what I figured. Just checkin' haha... Idk, I run a lot of hotrods and a carburated engine will see benefits with a spacer between the plenum and carb.
  7. May 18, 2010 at 11:10 AM
    Wreckless_71
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    yeah but the air/fuel isn't dumped into the venturi right before the TB spacer?
  8. May 18, 2010 at 12:51 PM
    supremetaco2
    supremetaco2 Well-Known Member
    concrete jungle, oahu
    04inacoma
    +hp, lifted, lights, dif breather mod, debadged, shorty antenna...
    sounds like i get boost in my truck! lolololool
  9. May 19, 2010 at 12:15 AM
    2004Taco
    2004Taco Well-Known Member
    Long Beach,CA
    04 PreRunner SR5 Trd
    Magnaflow and Deckplate Mod Billet grille
    i was talk to guy with an 07 taco. He had a spacer and he said he noticed better bottom end and MPG.
  10. May 19, 2010 at 1:15 AM
    rmarqu2
    rmarqu2 YES... i am a murse....
    Roger
    Baton Rouge
    09 Black 4x4
    FOX 2.5 coilovers, FOX 14" rears, AP expos, AP front plate bumper and skid, lightforce 240 blitz, warn m8000, 3/8 amsteel, BAMF sliders, cheap Chinese rock lights, ARB lockers all around
  11. May 19, 2010 at 2:16 AM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    ...snake oil....
  12. May 19, 2010 at 3:17 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    exactly
  13. May 19, 2010 at 6:45 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    its called a placebo effect
  14. May 19, 2010 at 10:32 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    I would use it to prop a door open on hot days while working in the garage. That's about it.
