Throttle body spacers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by oostroma, Nov 1, 2018.
  1. Nov 1, 2018 at 8:21 PM
    oostroma
    oostroma [OP] (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    It seems the pedal commander is just fooling the ECU into thinking the pedal is in a more advanced position. Comments?
  2. Nov 1, 2018 at 9:20 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Make sure everyone in the truck picks their feet up. That will decrease weight and increase your HP to weight ratio and that, my friend, will give you the increased thrust ratio you are looking for.
    TireFire likes this.
  3. Nov 1, 2018 at 9:25 PM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    If this actually worked, don’t you think toyota engineers (or any manufacture engineer) would have extended the TB housing by a half inch or so?
  4. Nov 1, 2018 at 9:25 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Yeah and don't forget to UPGRAYYYED your engine to a carburetor system first
  5. Nov 1, 2018 at 9:31 PM
    Marcmtb1
    Marcmtb1 Well-Known Member
    PHX, USA
    2016 Tacoma TRD OR DCSB 4x4
    5100/885 w/ 1/4 lean spacer, Icon RXT w/ B110’s, 255/80/17 FWP, AP Apex Sliders, KDMax 87, ADD W1, BD mirror riser
    Throttle body spacers don’t work. The idea worked with carburetors but doesn’t make a difference anymore. Tried on my 1st gen Tacoma.
    If you have $100, find a used Shift Sense Pro (SSP) on TW. - basically manually shifts trans in sport mode and has speed thresholds for each gear that make the engine operate in ideal rpm range. Feels peppier. I love mine.
    If you have $700, get the Orange Virus Tune. Get HP increase and new shift map.
    wahoobie and Tac0Tic0 like this.
  6. Nov 2, 2018 at 7:35 AM
    802coma
    802coma Well-Known Member
    Caleb
    NEK & Southern VT (Berkshires occasionally)
    '10 Reg Cab 4x4 MT
    That's exactly what it does. But it'll change the way your truck drives (well, responds). It'll feel better than the spacer. It also has an eco mode which deadens the gas pedal and allows you to get better milage. Also helps for throttle control Offroad or in icy conditions.
  7. Nov 2, 2018 at 10:31 AM
    CoastieRon
    CoastieRon Hammocking Fool
    Ron
    Nashua
    Lil' Silver
    Too much.
    this is the best thread today.....
    Tac0Tic0 likes this.
