Throttle Cable Help!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by YotaBro, Sep 30, 2023.
  1. Sep 30, 2023 at 5:31 PM
    YotaBro
    YotaBro [OP] Well-Known Member
    98 Tacoma
    Hey guys, so I just swapped the throttle body on my 98 3.4l manual 4x4 tacoma (was having a high idle), with a throttle body from a 98 4runner. Everything is pretty much plug and play, except now my throttle cables each are about an inch off. One is an inch too short, and the other is an inch too long (this is with them maxed out via the adjustment screws. See pics attached.
    Is there any way to adjust the cable length? Like the thin metal wire, not the whole black housing?
    Any idea what I should do to fix this? Help is appreciated!!
    Kick back cable is too loose:
    Throttle cable is like an inch too tight (not long enough to fit back into the original bracket)
  2. Sep 30, 2023 at 6:53 PM
    Potomus Pete
    Potomus Pete Love my little truck
    Hippy
    Sarasota Florida The Great Place To Live.
    1999 Prerunner single cab. With a BO7A rear end
    All kinds 3 inch body lift/2 1/2 suspension lift. 31/11 1/2/15 tires All work done by myself for years. The only work performed by mechanic was fuel pumps. I also have a 90 Mustang 350 hp and I can never understand how come my Tacoma gets more respect Just got a 99 Jeep TJ that I rebuilt, and painted in the garage
    Washers?? A series of washers. Drill new holes in the plate?
  3. Sep 30, 2023 at 7:05 PM
    YotaBro
    98 Tacoma
    Not sure I'm understanding, or that that would work?
  4. Sep 30, 2023 at 7:43 PM
    Smokestacks
    Smokestacks Well-Known Member
    BayArea
    1996 3.4L 4x4 Tacoma extra cab MT.
    Eaton Truetac limited slip Bilstein 5100s struts set at 2” 5100s shocks Torch add a leaf B&M short throw shifter Hella h4 headlights Warn front hitch Curt rear hitch Sony DSX-GS900 Deck Custic 1000watt amp Alumpro 10” sub Lund Steel Gullwing tool box Broadway rearview mirror Weather tech window deflectors
    Why not get the right one? If you want that to work you’re going to have to run the cable around something or Redo the end. Probably find something to crimp on to the cable. The short one your kinda screwed your self bud. In less you find a shorter path.
  5. Sep 30, 2023 at 8:21 PM
    YotaBro
    98 Tacoma
    I was told it was off a 98 4runner manual, which would be the exact same engine as mine. Obviously didnt intend to run into this problem.
    Looks like I'm gonna ship my old one to Maxbore, get it rebored, then install it cause I've pretty much narrowed down my high idle issue to the throttle body butterfly.
    Orignal TB:
    Swapped 4runner TB:
    Jon64l likes this.
  6. Sep 30, 2023 at 8:30 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    You won't be disappointed with Maxbore, mine is great!
    YotaBro[OP] likes this.
  7. Sep 30, 2023 at 8:32 PM
    YotaBro
    98 Tacoma
    I've heard he's good. Funnily enough tho if you look at the pics, the gap between the two looks very similar, so I'm kinda puzzled why the swapped TB idles lower, cause there's still clearly a gap...
  8. Sep 30, 2023 at 8:32 PM
    Smokestacks
    BayArea
    Nice. Hope that fixes it. How high did it idle? I wonder if anybody has had that spring lose its closure tension.
  9. Sep 30, 2023 at 8:39 PM
    Jon64l
    Jon
    The butterfly sits in a slightly different position because of thrust wear. Sometimes it's perfectly center, sometimes it's to the left or right. I was able to make mine idle well if i messed with the throttle body. With the pedal it would usually hang up and hold high idle. All gone after Maxbore. They installed a washer for thrust and adjusted Tps too. I opted for the least amount of bore so there is room in the future if need be.
  10. Sep 30, 2023 at 8:46 PM
    YotaBro
    98 Tacoma
    It was idling at at 1500 sometimes higher. When I swapped the TB, it was idling roughly the same, but I unplugged the battery and now its running at 850ish which is normal.
    Ok that's good to know. Did you tell them to install the washer or adjust Tps or did they just do it anyways?
  11. Sep 30, 2023 at 9:44 PM
    Jon64l
    Jon
    They just did it. Way more service than I was expecting.
