Throttle concern
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gincoma, Oct 30, 2012.
  1. Oct 30, 2012 at 11:38 AM
    Gincoma
    Gincoma [OP] Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    This has been happening since day one and it doesnt happen alot, maybe 3 times a month. While im driving (example)and pull into a gas staion I go and get what i need with truck still running in park, I reverse then put it into drive I give it throttle and nothing happens for about 2 sec then it goes. I was wondering if im the only one who experiences this or if its part of all the gadgets that came on the 09+ tacomas (traction control etc..etc..) Any input?
  2. Oct 30, 2012 at 12:06 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    How fast are you moving the shifter between gears and wanting to use the gas? Is your foot on the brakes?
    From park, (foot on brake) I'll put it directly down into reverse (or drive) and I won't give it any gas until I can 'feel' the truck jerk a bit. After I feel that slight jerk, I'll know to take my foot off the brake and give it gas. No hesitation at that point.....
    I have an 07 without all the traction control gizmos.
  3. Oct 30, 2012 at 12:12 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    My '09 does this very thing every so often , as you said , from reverse to forward
  4. Oct 30, 2012 at 12:13 PM
    Gincoma
    Salt Lake City UT
    I do it at a normal pace, I wait until its lost momentum from reversing then I put it into drive and give it a little gas to go and nothing happens for about 2 sec and it hardly happens but when it does it bothers me.
  5. Oct 30, 2012 at 12:16 PM
    Gincoma
    Salt Lake City UT
    Good to know im not the only one, Im just wondering if it has anything to do with the traction control systems installed on the 09+ tacomas :confused:
  6. Oct 30, 2012 at 12:33 PM
    MTLTaco
    MTLTaco Well-Known Member
    Montreal
    09 Double Cab TRD
    09 and up have an electronic throttle I believe. I experience the same thing when I don't wait long enough for it to ingage in gear. Always thought that was it????
  7. Oct 30, 2012 at 12:56 PM
    Good351
    Good351 Well-Known Member
    Ames, IA
    03 4Runner V8
    My 08 does this too..since day 1. And it'll happen when going from reverse to drive, or park straight to drive. I always wait to feel the trans engage, then gas..but sometimes it will not let the engine increase rpm. It feels like a stall our or a bog..but I know it's just the electronics limiting the engine for some reason.
  8. Oct 30, 2012 at 12:58 PM
    Gincoma
    Salt Lake City UT
    from 05 and up there all throttle by wire
  9. Oct 30, 2012 at 10:18 PM
    Janster
    Jandy
    Lancaster, PA
    So, you're moving the shifter while the truck is still moving?
  10. Oct 30, 2012 at 10:24 PM
    OZ-T
    Peter North
    British Columbia
    Exactly
  11. Oct 31, 2012 at 11:47 AM
    Gincoma
    Salt Lake City UT
    not at all im at a complete stop then put it into "D".
  12. Oct 31, 2012 at 11:49 AM
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Video would help
  13. Oct 31, 2012 at 11:51 AM
    OZ-T
    Peter North
    British Columbia
    I don't think you could show it on video , it's just a lag in the response to your throttle input
  14. Oct 31, 2012 at 12:03 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Yes it would be a pain to catch on video if it only happens for 2 seconds at a time, a couple times per month. But it definitely doesn't sound normal... if you are completely stopped, then engage drive gear and take your foot off the brake, there should definitely be some response to throttle application. I also suspect it's something with the traction/drivetrain/tranny gizmos or maybe the throttle-by-wire system. Good luck, let us know if you find anything conclusive.
  15. Oct 31, 2012 at 1:28 PM
    Gincoma
    Salt Lake City UT
    Im going to ask the dealer this weekend when i take my truck in for the "harsh ride TSB" Im pretty sure it will be inpossible to duplicate at the dealership and theyll send me on my way. Then when i back out of the dealership itll happen lol
  16. Oct 31, 2012 at 6:38 PM
    Pro Taco 11
    Pro Taco 11 Sitt Head
    Rob
    Joliet, Illinois
    Tacoma TX Pro 2011 4x4
    3" OME, RAAL, TRD Exhaust, Pioneer DBL DIN, Weather Tech's, Bull Bar, AFE CAI, Anytime Fog, Map/Dome light mod, Ultra Gauge, Tail Gate theft mod, Second Set of D-Rings in bed, Dura Tracs 285's, Satoshi deep dish, Leer 100 XQ, Wet Okole seat covers
    My 2011 Tx Pro does it too. Doesn't matter if on a grade of flat roads. Every once in a while, not every time. Like a pause from reverse to drive and then a surge and the truck takes off. Never from drive to reverse though. I am at a complete stop while shifting from reverse to drive.
  17. Mar 14, 2013 at 5:38 AM
    Booger
    Booger Active Member
    Josh
    Mississippi
    '10 TRD Off Road, OD Green, Debadged
    Black diamond plate flooring (rubber), back up cam anytime mod,Painted, Matte (OD) Green and black
    Same here with with my 10', stall, then a surge and take off. Not very often, and only from reverse to drive.
  18. Mar 14, 2013 at 9:19 AM
    CLODHOPPER
    CLODHOPPER Well-Known Member
    EDMONTON, AB
    05 tacoma
    Chrome black mesh grill, Devil horns taco emblem, Halo Headlights/HID's 8000k, Snow Camo back window decal, Hard top Tonneau cover, Zone 6" suspension lift, Fuel Tri Ace 35x12.5R18's on pro comp rims.
    I think its pretty normal for the truck to take a couple seconds to switch from reverse to drive, careful about hitting the trottle right after you switch gears tho. If you get the rpms too high right after you switch, you'll turn your tranny into mashed potatoes... doesnt sound like its too big of a concern tho.
  19. Mar 14, 2013 at 1:29 PM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    Are you using the brake to stop from reversing or just letting the truck come to a stop?
    Use the brake to stop, keep depressed while shifting.
  20. Mar 14, 2013 at 2:32 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Thats what I was thinking.
