Throttle, hand control (5VZ)
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoDell, Mar 21, 2013.
  1. Mar 21, 2013 at 12:22 AM
    TacoDell
    TacoDell [OP] Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    check out muh video...
    http://www.youtube.com/watch?v=VrDpAhVujdM&feature=share&list=UUrC21XIO5oNaLx3Lj51uqfA
    wuz purdy simple to do
    the video might offer some visual orientation.
    not pictured in the video was the routing of the cable
    from the firewall to the gear shift lever...
    Cable comes in under the console plastics
    and rises up inside the gear shift boot to reside in the lever's seat.
    not mine... but looks like this when stripped...
    here's a couple detail pics of the cable end / linkage...
    most the necessary parts were purchased off ebay fairly cheap
    I used SRAM 1.1mm X 2200mm SS wire cable.
    with 6ft L. X 4mm OD sleeve/casing (1.2 mm teflon inner core)
    * I purchased 7' of each because I wasn't sure (was shortened)
    Sunrace SLM10 friction shifter (left control)
    was purchased from Amazon
    I wanted to say thanks to Skyler (wolfgang123@TW)
    for sharing some links with me, made it super easy
  2. Mar 21, 2013 at 12:25 AM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Awesome! :thumbsup:
    I've seen this once before on an older rig, and I'm assuming this is so you can use the brake while ascending up hill in a manual? Very cool...too bad the 2nd gens are all fly by wire.
  3. Mar 21, 2013 at 12:42 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I like it man. Turned out good. Need to do this too.
  4. Mar 21, 2013 at 1:06 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Cool, I like it! kind of like a poor man's crawl box... :thumbsup:
  5. Mar 21, 2013 at 1:49 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    thats freaking awesome....
  6. Mar 21, 2013 at 6:49 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    heres mine on the 3rz:
    the cable burred pretty bad at the end before i put my crimp end on there so i might just buy a new one and redo it since it kinda got damaged through out my trail and error setup process.
  7. Mar 21, 2013 at 12:43 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    hey Skyler... thanks for adding to the thread :)
    here's a lesson learned...
    so I was pushing the cable thru,
    after getting the housing in place.
    all of of sudden bacon's sounding off...
    and I see some light smoke :eek:
    came to realization that my cable, as it was pushed thru,
    had followed a path that ground the pos+ and neg- terminals
    on muh auxillary battery... :facepalm:
    no real harm... ( ...except :eek: )
    just discolored the wire at the section (end)
    I was planning to cut off anyway.
    just sayin...
    so attention is given as to where that wire runs :D
  8. May 3, 2013 at 3:55 PM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    I just wanted to add something to this. If you have a supercharger then you are going to have to make a bracket similar to the 4cyl one so that you can mount the new cable parallel to the factory cable. Here is a couple pictures of mine.
  9. May 3, 2013 at 4:01 PM
    Aw9d
    Aw9d That one guy
    Great idea!
  10. May 3, 2013 at 6:52 PM
    BamaToy1997
    Bill
    Navarre, FL
    I know this is probably a moot point, but I would be worried about the safety involved. With you being able to lock the throttle, what would happen if you were to accidentally trigger the throttle? What if you had an accident? You could accidentally pull the throttle, or hit it and have other problems. Just asking if you have considerations for that?
  11. May 3, 2013 at 6:57 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    i mean it goes through your head..... but theres always a clutch that works just great:cool:
  12. May 3, 2013 at 7:21 PM
    Southern01Taco
    Sean
    Holden, La
    The knobs that we used are adjustable so that it can either spring back like a normal throttle or tightened up to hold the rpms in one spot. I will leave mine loose for that exact reason. Just in case my hand bumps it, it will spring back like normal.
  13. May 3, 2013 at 8:21 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    So what is exactly is the purpose or function of this?
  14. May 3, 2013 at 9:14 PM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    If you have a 5 speed, you can leave your feet on the clutch and brake, without having to heel toe, when wheeling. I still need to do this...
  15. May 3, 2013 at 9:21 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    Thats pretty cool! What rpm can you get it up to?
  16. May 3, 2013 at 9:39 PM
    Southern01Taco
    Sean
    Holden, La
    I don't know about everyone else's setup but I can pull mine almost, if not completely, wide open. I haven't fully tested it yet but I know I pulled it to 4k and still had some left to go.
  17. May 3, 2013 at 10:06 PM
    Yamaha Dave
    Gotcha thanks. Learn something new everyday.
    :D
  18. May 3, 2013 at 10:18 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    ^ yep, what he said... except I call it a lever :p
    is the reason I selected this particular friction shifter.
    With the friction lever adjusted to minimal friction...
    The lever will move freely and return to neutral with the throttle linkage assembly.
    The lever's cable wire will extend out of the end of the throttle linkage, causing no bind.
    ^ (* using my attachment method) (* see muh video)
    And the lever receives zero feedback from the cable's movement.
    Add more friction to the lever (tighten) and it becomes a index type shifter.
    And holds solid at the index positions.
    No opposing lever feed back in this position either.
    If the cable end is attached in a different way then I did...
    It might be possible that lever feedback could occur.
    But enough slack in the cable end would likely bend/loop the wire
    rather then push back into the cable housing.
    ^ but it's something to be aware of if the cable end is attached differently.
    I'm fairly conscious about everything on muh junk...
    Knowing it is there and how to use it... makes ya smarter.
    Safe is only as good as one makes that.
    If yer a dummy... ya probably shouldn't do this mod ;)
    * Southern01Taco
    thanks for the details regarding the SC cable mount differences :)
  19. May 4, 2013 at 6:43 AM
    Southern01Taco
    Sean
    Holden, La
    Yea, lever, that sounds much better. I couldn't think of a proper term for it last night for nothing lol.
    And no problem, I didn't realize the cable mounts were that different until I went to install the second cable.
  20. May 4, 2013 at 10:14 AM
    BamaToy1997
    Bill
    Navarre, FL
    I see the aspects that you are all talking about. I guess sometimes I do tend to over analyze things. Just in my nature.
