Throttle Hesitation-Slight Engine Skip
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mcmmotorsports, Aug 21, 2016.
  1. Aug 21, 2016 at 4:10 PM
    mcmmotorsports
    mcmmotorsports [OP] Well-Known Member
    Michael
    2016 MGM Tacoma TRD OffRd Access Cab
    So, I had the transmission TSB performed last week and hoped that it would clear up this issue but no luck. Basically, and tell me if any of you feel it as well, when accelerating 25%-40% throttle, it feels as almost there is a slight misfire. Very slight, very subtle, but I can feel it. I haven't addressed it with the dealer yet since they may tell me I am nuts but I can feel it. Anyone else?
  2. Aug 21, 2016 at 4:12 PM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    What speed, RPM, gear?
  3. Aug 21, 2016 at 4:13 PM
    mcmmotorsports
    Michael
    No specific speed or gear. Does it while accelerating
  4. Aug 21, 2016 at 4:15 PM
    Aussiek2000
    2016 Offroad AC
    Probably just the torque converter clutch being locked up. They lock it at low speeds and it tends to cause the engine to chug. Like putting a manual in too high of a gear
    zoo truck likes this.
  5. Feb 21, 2017 at 10:29 AM
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Not sure if there is a newer, more appropriate thread but, my truck does this. Most noticeable on steady up hill climbs with RPM less than 3k and partial throttle.
  6. Feb 21, 2017 at 10:36 AM
    Rownan
    Rownan Well-Known Member
    Tim
    Highland, MI
    '17 OR DCSB 6MT *Quicksand*
    Yep, my manual trans Tacoma falls on its face around 2000-2500 rpm.
    It has been mentioned on here by others as well.
    I think it's just one of the quirks of this powertrain.
  7. Feb 21, 2017 at 11:14 AM
    swimmer
    Tucson
    2016 TRDORAC4WD
    Does it feel like a soft spot in the power curve or does it feel like an engine stumble/misfire?
  8. Feb 21, 2017 at 11:33 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Same thing here - it's not quite as bad after the Rev 1 TSB b/c it doesn't seem to hover in the same RPM range on acceleration, but I still feel it unless I'm heavy on the foot. And being heavy on the foot isn't always possible when dealing with city traffic. I'm just not sold on whether its a quirk of the power train or something is wrong - doesn't feel like it should seem like a miss or, as another TW member described it, "like a fish tugging on bait"
    Trey3 likes this.
  9. Feb 21, 2017 at 12:06 PM
    Rownan
    Tim
    Highland, MI
    Mine is more like a flat spot. It doesn't feel like a misfire. I notice it more upon throttle tip-in when accelerating in a high gear.
    If I downshift and accelerate from 3k rpm, the torque curve feels more linear.
    That's why I think it's just a character of the engine. Seems to be predictable, in the same area of the powerband.
  10. Feb 21, 2017 at 12:09 PM
    swimmer
    Tucson
    2016 TRDORAC4WD
    Mine feels more like a misfire or stumble. Steady throttle. When at higher rpms I don't notice as much/at all.
  11. Feb 21, 2017 at 12:10 PM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    Yep, below about 2200 RPM outside of 1st gear and you are going nowhere anytime soon.
    Also I find that if I mash the gas in that RPM range the torque is highly non-linear (almost like a sine wave) bobbing the truck back and forth until it gets to about 2500+.
    I shift higher up in the RPM band to avoid it unless I'm in a traffic situation where I know I won't need to get up and move.
  12. Feb 22, 2017 at 6:33 PM
    mcmmotorsports
    Michael
    Yup, another thread discusses this. I have it. Ethanol free fuel seems to be the fix. I am still doing some testing:
    https://www.tacomaworld.com/threads/slight-miss.448072/
  13. Jan 27, 2020 at 6:13 AM
    apwzzz
    apwzzz New Member
    Andrew
    2016 Tacoma TRD Sport
    I have a 2016 TRD Sport with 96,000, Has been chugging since new, they have changed my torque converter, done about 3 different tranny software updates and still chugging so over the weekend I went and got a new set of spark plugs at the dealer and pulled the first old one out and it was gaped at .25, they're supposed to be .40, all of the plugs from the factory were between .25 and .30, I properly gaped and installed the new ones and went for a ride, no more chugging it completely fixed it!!
    Kolohe07 and El Chivo Norteño like this.
  14. Jan 27, 2020 at 6:19 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    93 Octane fixes the low throttle miss my truck has. Done it for 50k miles now.
    bshammer0 likes this.
  15. Jan 27, 2020 at 6:25 AM
    bshammer0
    Brandon
    Nashville, TN
    Same. I've run nothing by 93 octant for over 2 years now primarily for this reason, as well as the drastic reduction in engine vibes and overall smoothness... I didn't think I was buying a vehicle that needed 93 for me to enjoy driving it, but here we are... ;)
    Lt. Dangle[QUOTED] likes this.
  16. Aug 2, 2022 at 4:23 AM
    Trey3
    Trey3 Member
    2010 tacoma trd spord 2x4
    None
    I can relate in my 2017 trd
  17. Aug 2, 2022 at 5:22 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I think its pretty common. a buddy sort of complained similar as the op his 2019 trd did this. The transmission would shudder in 6th gear at very low rpm around 1200. He had the tsb upgrade, but said it was still the same after. He just lived with it.
  18. Aug 2, 2022 at 7:48 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    it feels like it's starting to lug. when mine does this, with a obd scanner hooked up, you can see it retarding timing in real time. it will go from 8, to 7, to 6, 5, 4, 3 degrees, etc. the more timing retard, the worse it feels. it usually happens on low-medium throttle hill climbs. i think the truck is trying to hold the gear but it's starting to knock so the ECU is retarding timing.
  19. Aug 2, 2022 at 7:50 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    someone replied to an old thread and tricked you guys in to replying to people that no longer log in here :D
  20. Aug 2, 2022 at 7:51 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    the topic is still valid
    VB25 and Lt. Dangle like this.
