throttle issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueT@com@4×4, Nov 12, 2022.
  1. Nov 12, 2022 at 2:50 PM
    BlueT@com@4×4
    BlueT@com@4×4 [OP] Well-Known Member
    2015 TRD PRO Tacoma
    Hi Guys,
    As you know I got with state inspection for my taco but now I can pass it but once I pass inspection my MIL is on and got some code before, the code about MAF sensor and SAI system.. I go head test my MAF sensor with multimeter and weird stuff is, as I depressed pedal accelerator the number on multimeter going down instead going up, so I replace the MAF sensor but when I drive my truck suddenly my truck won't run over 50mile/hour even I depress accelerator pedal all the way down.
    Once I check again turns out the throttle butterfly won't fully open when I depressed gas pedal, so I un install pedal commander but still same. What you guys think cause the throttle butterfly won't fully open?
    When I depressed gas pedal all the way down and the throttle only open 20%,
    Do you think pedal commander ruin my accelerator pedal?
    Thank you guys
  2. Nov 12, 2022 at 8:00 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    When is the last time you cleaned it
  3. Nov 12, 2022 at 8:08 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Aren’t you supercharged and running a different throttle body?
    Or am I thinking of someone else?
  4. Nov 12, 2022 at 8:35 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    A secondary air injection system fault will cause the truck to go into limp mode as you described so you will need to diagnose that first.
  5. Nov 13, 2022 at 4:22 AM
    BlueT@com@4×4
    2015 TRD PRO Tacoma
    Not long time ago.
  6. Nov 13, 2022 at 4:23 AM
    BlueT@com@4×4
    2015 TRD PRO Tacoma
    Not yet but on the road there. Definitely someone else
  7. Nov 13, 2022 at 4:27 AM
    BlueT@com@4×4
    2015 TRD PRO Tacoma
    Woow.... that big part of SAI system for the engine.
    Before this happen I got P2433 and P2438 but now I got only P2433, is it for the air pump?
    But I test straight from battery the pump work and when I turn engine off I hear pump too.
  8. Nov 13, 2022 at 4:29 AM
    BlueT@com@4×4
    2015 TRD PRO Tacoma
    I test both the air injection valve too and both open and close too,
