throttle linkage adjustment
Discussion in '1st Gen. Tacomas (1995-2004)' started by mtnsdesert, Dec 7, 2016.
  1. Dec 7, 2016 at 11:46 AM
    mtnsdesert
    mtnsdesert [OP] Member
    95 tacoma 4x4 sx
    totally stock except tire size
    Little trivial but anyone know the correct procedure to adjust the throttle linkage properly so not too fast idle speed when cold and correct idle rpm when warm? I have a 95 Tacoma 3.4 manual trans. Thanks
  2. Dec 7, 2016 at 12:23 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    The throttle plate should be completely closed. There is an adjustment screw that the linkage hits to absorb the force of the closing throttle. Make sure this screw is set so it gets hit as the throttle is completely closed, otherwise the throttle plate will wear the inside of the throttle body.
    The cable should have just a millimeter or two of slack when closed.
    The Idle Air Control (IAC) valve controls the cold and hot idle speed.
    Download the factory repair manual pdf for the exact procedure and specs for the cable adjustment.
    mtnsdesert[OP] likes this.
  3. Dec 7, 2016 at 12:34 PM
    mtnsdesert
    95 tacoma 4x4 sx
    Thanks for the input!
