Throttle Position Sensor 89452-35030
Discussion in 'Performance and Tuning' started by JBTacoma, May 19, 2016.
  1. May 19, 2016 at 12:50 PM
    JBTacoma
    JBTacoma [OP] Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    deleted
    shr133 likes this.
  2. May 20, 2016 at 9:20 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    To compliment that, a person could also purchase a used throttle body for about $150.
  3. May 20, 2016 at 5:37 PM
    JBTacoma
    Jeff
    Cullman Alabama
    You would have to find one that Has a 4 wire plug and very few did. Toyota only used these on a few 4Runners and a few Tacomas. The computer want recognize the 3 wire ones. Most had a 89452-35020 3 wire throttle position sensor. The few that have the 89452-35030 are 4 wire
  4. May 20, 2016 at 8:14 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Ohhh. Sorry. I was speaking of a 2nd gen. Didn't even realize that yours was a 1st gen. My apologies.
  5. May 23, 2016 at 8:50 PM
    RPain
    RPain Well-Known Member
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    When my 2003 4-wire sensor went bad I bought a used throttle body from a junk yard off of a 2001 4-runner with a 4 wire, swapped the entire throttle body setup and it worked great. Search http://www.car-part.com/ to find one at a junk yard near you.
    Torspd likes this.
  6. Sep 5, 2016 at 6:05 AM
    MARK97XP
    MARK97XP Well-Known Member
    Mark
    Spokane
    03 SC DC 4WD TRD OR
    Yep thats exactly what i did after experiencing my throttle cutting out on and off for a couple years. Bought a used one for under $200 and swapped it out and has worked flawlessly since.
  7. Sep 5, 2016 at 6:22 AM
    Clearwater Bill
    Billy
    Largo Florida
    Your tip and P/N can be very valuable.
    But to whom? Can you include the year models and engines this tip is for?
