Throttle position sensor help
Discussion in '1st Gen. Tacomas (1995-2004)' started by altidude, Jul 7, 2010.
  1. Jul 7, 2010 at 4:47 AM
    altidude
    altidude [OP] Member
    Colorado
    2011 TRD XCab Pyrite Mica
    1998 prerunner 3.4.My CEL is on, getting a 0120 code. I've replaced the TPS, and cleaned the throttle body. Any suggestions on what to do next?
  2. Jul 7, 2010 at 7:06 AM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    MAS...is it running rough?
  3. Jul 7, 2010 at 7:08 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  4. Jul 7, 2010 at 7:26 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Code does not always=replace part. Check the wiring and connections for shorts/opens and corrosion. Put dielectric grease in connectors as you go.
    Good luck
  5. Jul 7, 2010 at 11:02 AM
    altidude
    Colorado
    The cel would come and go until I replaced the tps, now it seems to stay on most of the time. Starts hard, dies,won't shift correctly.
    I did do a search about this, but there seems to be no consistent cure for the problem. I have checked for loose connections, tried moving the tps slightly, cleaning the throttle body, and finally replacing the tps. Now in the proccess of checking voltage and resistance.
    I have never replaced the oxygen sensors. Wouldn't that be giving me a different code?
    I will clean the mas. Probably needs cleaning again anyway.
    Thanks for the help!
  6. Jul 7, 2010 at 11:13 AM
    Coolidge
    Coolidge Well-Known Member
    So Cal, Ca
    2003 Pre Runner
    King coilovers frt +3". Bilstein 5100 shocks rear w/AAL, K&N FIPK, Magnablow exhaust, Billet grill, clear corner lights, Sony stereo, JBL, Sub etc.
    Are you running a cold air intake? If so, def clean the MAS. But be careful. I just did my 03, but I think the earlier MAS are a different design.
  7. Jul 7, 2010 at 11:29 AM
    altidude
    Colorado
    I did the deck plate mod. Does that have anything to do with it?
  8. Jul 7, 2010 at 2:06 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    what type of tps sensor did you put back in...oem or aftermarket?
  9. Jul 7, 2010 at 3:04 PM
    altidude
    Colorado
    Aftermarket from NAPA.
  10. Jul 7, 2010 at 3:54 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    honestly....that could be the problem.
