throttle positioning sensor
Discussion in 'Technical Chat' started by livel0veryde, Jan 23, 2013.
  1. Jan 23, 2013 at 11:00 PM
    livel0veryde
    livel0veryde [OP] Well-Known Member
    josh
    missouri
    Tacoma based buggy
    Can anyone tell me how to properly adjust the throttle positioning sensor.
    EDIT: im working on an 2004 5vz 4x4
  2. Jan 24, 2013 at 6:13 AM
    livel0veryde
    josh
    missouri
    Tacoma based buggy
  3. Jan 24, 2013 at 8:03 AM
    BamaToy1997
    Bill
    Navarre, FL
    If you are referring to an 04 Tacoma, I do not show any indication in the diagnostics that says there is any kind of adjustment. I will check again to see, but perhaps giving a more detailed opening post that mentions truck details would be more helpful next time you are needing help.
  4. Jan 24, 2013 at 11:27 AM
    livel0veryde
    josh
    missouri
    Tacoma based buggy
    You can loosen the two screws that hold the tps on, then you can spin the tps to get like 20 degrees of adjustment.
  5. Jan 24, 2013 at 2:52 PM
    BamaToy1997
    Bill
    Navarre, FL
    Never seen that much adjustment before on any TPS. Typically they have only about 4* of movement. Is your replacement TPS an aftermarket one? On the ones I have replaced on a Tacoma I have installed it, centered it, and left it there. Never had any problems with them after that.
