Throttle spacer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brooklyn396, Jan 14, 2018.
  1. Jan 14, 2018 at 10:12 AM
    brooklyn396
    brooklyn396 [OP] New Member
    Dave
    2015 Tacoma
    Anybody have any info on throttle spacers? Looking for a little better performance and maybe a little better mpg.
  2. Jan 14, 2018 at 11:03 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Save your pennies and spend it elsewhere.
    taco2010trd and REDdawn6 like this.
  3. Jan 14, 2018 at 11:25 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I think this is one of those mods that benefits carbureted engines and does little to nothing on fuel-injected engines.
    REDdawn6 likes this.
  4. Jan 14, 2018 at 3:00 PM
    Wainiha
    Wainiha Well-Known Member
    agreed i bought 1 for my 2000...save for S/C and fuel solution
  5. Jan 14, 2018 at 4:40 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Throttle body spacers are 100% pointless on a port injected motor.
    Now, OP if you meant an intake manifold spacer (like the one XTP Sells for our v6's) that creates longer intake runners which helps with low end torque n power, then yes those do help some.
    Capt. Obvious and outlawtacoma like this.
  6. Jan 14, 2018 at 4:46 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    More Snake Oil just like aftermarket Cold Air Intakes.
    taco2010trd and outlawtacoma like this.
  7. Jan 14, 2018 at 6:46 PM
    Wainiha
    this
  8. Jan 15, 2018 at 7:00 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Always wondered about these. Do they really work? Haven't seen any independent dyno numbers. Is it worth getting for $265?
  9. Jan 15, 2018 at 4:16 PM
    nd4spdbh
    SoCal
    I have one on my truck, from the butt dyno it made a difference in mid range giddyup, i think XTP has dyno numbers, but no independent sources
  10. Jan 23, 2018 at 3:03 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I've had them on past trucks. Blah. Might get one now just to punch for my methanol nozzle.
