Throttle stuck wide open!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jhammerson93, Jul 29, 2019.
  1. Jul 29, 2019 at 7:29 PM
    Jhammerson93
    Jhammerson93 [OP] Well-Known Member
    Justin
    05 tacoma SR5 4x4
    2.5" leveling kit, aftermarket 16" rims, 2" hub centric wheel spacers
    i was driving home, cruising at about 65. I put the truck in neutral to pull off the highway, and suddenly the truck revved all the way up the the limiter! I tapped the gas peddle and nothing. Turned the truck off and coasted into our driveway. Turned it back on and no problems. I’m thinking throttle position sensor, or the throttle body motor. Any ideas?
    wilcam47 likes this.
  2. Jul 29, 2019 at 7:37 PM
    badger
    badger Well-Known Member
    07 SR5
    Is this an auto or manual. I'm curious why you shifted to neutral? Was the cruise control set when you shifted to neutral?
  3. Jul 29, 2019 at 7:38 PM
    Jhammerson93
    Justin
    05 tacoma SR5 4x4
    Sorry should’ve mentioned that. It’s a manual. I just dropped it into neutral while braking to turn onto my road. I didn’t think about cruise control though. Normally it shuts off when the break or clutch is pressed
  4. Jul 29, 2019 at 7:46 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Maybe you have a defective clutch switch.
  5. Jul 29, 2019 at 7:47 PM
    Jhammerson93
    Justin
    05 tacoma SR5 4x4
    But also the brake switch? I’ll have to test this tomorrow.
  6. Jul 29, 2019 at 7:51 PM
    badger
    07 SR5
    My first suspicion would be a failing TPS
    Jhammerson93[OP] likes this.
  7. Jul 29, 2019 at 7:52 PM
    Bishop84
    Bishop84 Well-Known Member
    .What kind of floor mat do you have?
    b_r_o, Wulf and tcjacado like this.
  8. Jul 29, 2019 at 7:56 PM
    Jhammerson93
    Justin
    05 tacoma SR5 4x4
    Weather tech matt style, but it was t on the pedal.
  9. Jul 29, 2019 at 8:03 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Have you cleaned the throttle body lately? It may be gummed up and sticky.
    Jhammerson93[OP], b_r_o and whatstcp like this.
  10. Jul 29, 2019 at 8:05 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    [sarcasm]
    Maybe you should sue Toyota for a stuck throttle. o_O
    [/sarcasm]
    Jhammerson93[OP] and b_r_o like this.
  11. Jul 29, 2019 at 8:08 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If he does, wouldn’t the truck NOT restart after turning it off?
    Of course, that is if the switch is bad constantly and not sporadically?
    Clutch In = Cruise Off
    Clutch In = Truck Starts
    Honest question. As I pretty much think of you and Muddin’ as the Yoda gurus around here.
  12. Jul 29, 2019 at 8:13 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I think thats 2 different switches...the clutch disengage switch is high and the clutch start switch is low. I remember I had to mash my clutch to the floor to get it to start, but to disengage the cruise I just tapped on the clutch pedal.
    TnShooter[QUOTED] and whatstcp like this.
  13. Jul 29, 2019 at 8:21 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Sounds like a stuck throttle body valve. They gum up, and it gets stuck. Usually they get stuck closed but I guess it’s possible for them to stick open.
  14. Jul 29, 2019 at 8:22 PM
    wilcam47
    Will
    Bourbon state
    easy way to check is go drive it, put the cruise on. hit the clutch see if it disengages, then hit the cruise again, then hit the brake and see if it dis engages...Maybe you hit the cruise resume when you put the clutch in...that will make it rev up also...
  15. Jul 29, 2019 at 8:34 PM
    TnShooter
    Deogee
    STOCK
    That would make since.
  16. Jul 29, 2019 at 8:53 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Yes, but most switches do not get stuck in a permanant condition.
    The clutch switch for starting is a Normally Open Contact, The one for cruise control is a Normally Closed Contact.
    http://www.customtacos.com/tech.old...6toyewd/06toypdf/ewd/2006/tacoma/h/em01d0.pdf
    http://www.customtacos.com/tech.old...toyewd/06toypdf/ewd/2006/tacoma/h/em01d19.pdf
    b_r_o, TnShooter[QUOTED] and T4RFTMFW like this.
  17. Jul 29, 2019 at 9:11 PM
    TnShooter
    Deogee
    STOCK
    Thanks for the clarification.
    I learn a lot of stuff here on TW.
    Hopefully we can keep people like you around for a while. Lol
  18. Jul 29, 2019 at 9:49 PM
    Muddinfun
    Muddinfun Well-Known Member
    Toyota put so many fail safes in the cruise control, I can't imagine there's any way that the cruise caused the runaway. NC switches, NO switches, etc. Beyond that, I've got nothing. It might be a good idea to make a call to Toyota customer care.
  19. Jul 29, 2019 at 10:14 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Id clean the throttle body and see how things go.
    Scan it for codes. Any weird electrical issue related to these drive by wire systems will sound the alarm as soon as a "out of range" situation is detected. There are multiple circuits that check/cross-check the relationship between the pedal sensor at your foot and the position of the throttle plate.
    If you dont have any codes id supsect a mechanical issue (not electrical) like a sticky plate. Throttle body units do go bad though. Its not common but they're around
    Hholiday15 and Jhammerson93[OP] like this.
  20. Jul 30, 2019 at 7:41 AM
    Taco'09
    Taco'09 Well-Known Member
    @Jhammerson93
    OP, you have an '05. When did you acquire the truck?
    If I were you I would go over to the Toyota main site and run your VIN to check and see if the series of recalls was done such as trimming the gas pedal, software revision, etc. Report back. If your truck has gone through several owners previously its entirely possible that one or more of the recalls was not done, and possibly the software reflash missed.
    Jhammerson93[OP] and PzTank like this.
