throttle vs. rpm
Discussion in 'General Automotive' started by danteisme, May 29, 2009.
  1. May 29, 2009 at 7:13 AM
    danteisme
    danteisme [OP] Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    my friend and i are having a debate, gas mileage related. on a non-carburated vehicle, what would yeild you better MPGs, more throttle at a lower rpm, or less throttle at a higher rpm? i guess this would only apply to manual trannies. for instance, say you're going 45 in 5th gear, so you're at a lower rpm but you may have to be heavier on the gas pedal. or would it be better to say be in third gear, and be lighter on the gas pedal?
    i'm saying the lower rpm with the heavier throttle, IMO a lower gear at higher rpm is gonna burn more gas. he thinks the more throttle at a lower rpm will burn up more gas because the engine is running less effeciently.
  2. May 29, 2009 at 7:15 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    More throttle at lower RPM.....less pumping losses on the engine.
  3. May 29, 2009 at 7:22 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    +1 cause the guy who posted this is a genius.
  4. May 29, 2009 at 7:24 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont know about "Genius".....:eek:
  5. May 29, 2009 at 7:25 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I'd say more throttle @ less RPM
  6. May 29, 2009 at 8:09 AM
    danteisme
    South Western PA
    it just makes more sense to me that way. if it were a carbed setup, i'd say that would be worse becuase you'd just be dumping fuel
  7. May 29, 2009 at 8:43 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    +2 and confirmed with my scanguage.
