throw-out bearing failure
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco R/C, Sep 14, 2010.
  1. Sep 14, 2010 at 5:18 PM
    Taco R/C
    Taco R/C [OP] Well-Known Member
    08 Taco 3in
    3inch lift , 18" rims
    Well, toyota just declined to replace my throw-out bearing under any type off warranty. the truck is out of warranty by 2000 miles. But it seems weird to me for a throw out bearing to fail at 38k miles. Sucks but it looks like imma be pullin the tranny on a 2008 4x4 tacoma. Any tips??
  2. Sep 14, 2010 at 5:26 PM
    RU55ELL
    RU55ELL Well-Known Member
    Russell
    ETX
    *sigh*
  3. Sep 14, 2010 at 5:31 PM
    joes06tacoma
    Joe
    Central Coast, CA
    If you're gonna go to the trouble of doing it yourself, buy the pdm kit first so you have it on hand.
    Mine goes in thursday for the first repair attempt on my throw out bearing. Mine is 4 years, 10 months old, 50K miles. The regional rep from toyota approved a clutch replacement on toyota's dime.
    I have my doubts whether this is going to fix the problem since they are not changing the bell housing. I did suggest that they consider that given the widespread issues with the six speed transmission. But, it's not costing me anything other than an hour or so to drop off and pick up my truck. So I will let them try it. If it were my own time and money, there is no way I would drop the trans before purchasing the repair kit from pdm.
  4. Sep 14, 2010 at 5:38 PM
    Taco R/C
    08 Taco 3in
    yea im still gonna try to connact a toyota rep. about my truck. the dealer told me today that toyota offered to pay half of the bill which was gonna be $820. that seems steep for only the bearing and input shaft. They were also not gonna replace the clutch while they had the trans out. which is stupid in my opinion.
  5. Sep 14, 2010 at 5:51 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Not really. I've seem premature throw out bearing failure many times. It's caused by sitting at a stop with the clutch pressed in for long periods of time. Even resting your foot on the clutch pedal with just the slightest amount of pressure can cause additional wear on it.
    Many people have the habit of doing this because they want to be ready to go or the driver is not very experienced at driving stick so they're afraid to stall under pressure when the light turns green.
    Not saying that's what you were doing. I used to tell people that if you don't need to use the clutch, don't put your foot on it until you actually need it. Forget about the other drivers on the road, let em wait for you to get the car rolling, it's your car, your money.
  6. Sep 14, 2010 at 5:54 PM
    Taco R/C
    08 Taco 3in
    yea that is hard on a bearing but thats not the case for mine. The only reason for mine going out is that i tow a boat almost every weekend. The boat is only 2400lbs loaded but i guess that doesnt help the matter.
  7. Sep 14, 2010 at 7:17 PM
    joes06tacoma
    Joe
    Central Coast, CA
    hey op, you have read the thread titled "throw out bearing again" right? It's been very popular for a long time. If not, go read it. It is not unusual to have issues with this particular transmission.
  8. Sep 14, 2010 at 7:18 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    That Sucks
