Throw out bearing going out...need to replace 1 1/2 year old clutch again?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jackson307, Jul 9, 2020.
  1. Jul 9, 2020 at 1:34 PM
    Jackson307
    Jackson307 [OP] Member
    Kristina
    2010 Tacoma Dbl Cab TRD
    I had a new throw out bearing, new slave cylinder, new clutch and the flywheel resurfaced 1 1/2 years ago. The throw out bearing is going out. One shop said they would have to replace the clutch at the same time and the Toyota Dealership said they can just replace the throw out bearing. Any comment on if a 1 1/2 year old clutch should be replaced because the throw out bearing is going out?
    Thanks!
  2. Jul 9, 2020 at 1:38 PM
    QuicksandTaco
    QuicksandTaco Well-Known Member
    Cody
    Oregon
    2015 Inferno TRD Pro 6spd
    URD short shifter, 285/75/16,
    Shops just recommend replacing the clutch since I believe it’s removed to replace the throw out bearing.
    there are some options out there for tob longevity since it’s a common annoyance on Tacoma’s.
    Side note, they all squeak so if your clutch is operating normally, the squeal isn’t hurting anything and you’d be fine not doin anything to it.
  3. Jul 9, 2020 at 1:39 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    How do you know it's going out? The throwout bearing chirp is incredibly common on 1st/2nd gens, mine chirped on my old clutch and new one started chirping again on the new clutch about 5k miles in. I just live with it, only 'fix' I've heard of is the URD one but even that doesn't always work from what I've heard.
    An actual throwout bearing failure is pretty rare on Tacomas
    20somethingwidataco likes this.
  4. Jul 9, 2020 at 1:48 PM
    Jackson307
    Kristina
    The chirp stops when the clutch pedal is pressed. I had 2 mechanics hear it and they agreed it was the throw out bearing. The truck shifts fine but the chirp is annoying.
  5. Jul 9, 2020 at 1:49 PM
    eon_blue
    Azusa, CA
    Yeah that's exactly what mine does. Used to do it all the time but it rarely does it nowadays for some reason. Comes and goes. I just live with it, I can all but guarantee if you replace the clutch again it will come back. Maybe try the URD kit if it's still available, seems to work for some.
  6. Jul 9, 2020 at 1:52 PM
    Jackson307
    Kristina
    I will look into the URD kit. Thank you!!
  7. Jul 9, 2020 at 7:46 PM
    TacoTuesday1
    FL
    isn't clutchmasters hydro TOB the fix for this
    QuicksandTaco likes this.
  8. Jul 9, 2020 at 10:38 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Normally after many miles it is recommended to replace them all as a set Clutch, pressure plate and throw out bearing...
    But considering yours is only a year and a half old I wouldn't, unless they have been abused. I would however inspect the clutch disk, pressure plate and flywheel when the transmission is out and make my call based on what I see at that time.
    The mechanic that stated they all must be replaced at the same time is trying to scam you as that is entirely false. Did he know it was recently replaced?
  9. Jul 9, 2020 at 10:53 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Jimmyh likes this.
  10. Jul 9, 2020 at 11:52 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    The URD sleeve kit works pretty good. The noise will likely eventually come back depending on conditions your driving in. Mine has came back after like 70k since replacement but its not as pronounced as it was before. Rather you really have to try to hear it over the clutch fan. And it only appears on cooler mornings.
    Jackson307[OP] likes this.
  11. Jul 10, 2020 at 12:54 AM
    Jackson307
    Kristina
    I reached out to URD and they responded that I could change the bearing but that it will probably start chirping again.
    Yes, the shop that said all would have to be replaced knew I had just had a clutch out in 1 1/2 years ago. I had asked him for a quote to just get the bearing replaced. I try to do a lot of research before I have anything done to my truck. Get tired of having them try to scam me into doing work I don’t need because I’m a woman. At a different shop they tried to tell me a serpentine belt for my truck was going to cost me about $79. I laughed and told him I could get a good one for $38 at Auto Zone. He quickly said he could do me a favor and match the price. I went and bought one and had a friend put it on instead.
    I won’t worry too much about the tob. I just hate the chirping when it’s loud.
    Jimmyh[QUOTED] likes this.
  12. Jul 10, 2020 at 12:56 AM
    Jackson307
    Kristina
    TnShooter[QUOTED] likes this.
  13. Jul 10, 2020 at 1:26 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Good for you doing the homework and research!
    Wishing you the best!
    Natetroknot and TnShooter like this.
  14. Jul 10, 2020 at 7:44 AM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Find another shop. No way to know if clutch needs replaced till you see it. Your orig. only lasted 8 1/2 yrs.? These days, they should, & usually do, last longer unless abused. Just my opinion.
  15. Jul 10, 2020 at 12:15 PM
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    noooooo.
    Edit: The urd sleeve kit does not resolve the chirping issue. It is designed to resolve shaft wear problems where the throw out bearing rides. The bearing itself is an OEM bearing that has had the inner diameter machined to fit over the sleeve and in operation is no better or stronger then OEM. They do offer a hydraulic throwout bearing which should work, but i've seen a lot of success with clutchmasters kit.
    yes!
    I've had way more clutch issues then i can count. The chirping comes from there being insufficient space for the throwout bearing to fully disengage from the pressure plate. As the friction disc wears it gets thinner and the pressure plate fingers stick further out making the already too small gap even smaller. This is where your chirping is coming from - The pressure plate fingers are contacting the throw out bearing with the pedal released. This additional wear will also cause premature failure of the throw out bearing.
    I would strongly recommend purchasing the clutch masters throw out bearing kit and one of their shim kits. This hydraulic TOB can be thrown in as is or be easily shimmed to fit aftermarket clutches, etc. This is the resolution to the issue.
    Natetroknot likes this.
  16. Jul 11, 2020 at 2:26 PM
    PNWTAC0MA
    PNWTAC0MA Well-Known Member
    Jessee
    Washington State
    2007 DCSB 6-Speed Manual
    Toytec boss lift Trd Pro rep grill Spec D headlights LED fog lights ARE Canopy
    Consider a clutchmaster TOB, I've heard those have more longevity over the URD TOB.
  17. Jul 11, 2020 at 4:14 PM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    When I bought my X Runner the TB had the chirp noise. Replaced the clutch and pressure plate, TB, slave cylinder and the fork. Truck had 93k miles all original.
    Toyota used either LUK or Aisin at the factory. Aisin seemed to be the preferred brand of the mechanics I talked to. Put it all back together and made sure to adjust the free play on the clutch pedal, yes there’s a service bulletin for that too. Insufficient free play causes the TB to spin all the time resulting in rapid wear. With everything set to factory spec I drove another 60k miles with no problems.
  18. Jul 11, 2020 at 4:28 PM
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    If the chirp stops when the clutch pedal is depressed, it's definitely not the throw out bearing. Throw out bearings make noise when you press the clutch pedal, because that's when it makes contact with the flywheel. If the truck makes noises all other times, it is likely pilot bearing or improperly installed/torqued clutch plate. I just had this same issue in my 2016 and it turned out to be improperly installed clutch plate, leading to a new clutch, flywheel, throw out bearing, and a hefty service bill. Genius shop gremlins tried to ram 2 bolts home through the flywheel after they cross threaded them, unsurprisingly it loosened and started to tear itself apart quickly. Clutch had as much wear after two weeks as my first one did after 4 years
  19. Jul 11, 2020 at 4:42 PM
    Gen2 Man
    Midwest
    07 Sport DCLB
    If you are talking about gen 2 truck 6 speed you really need to read the service bulletin. Then you’ll understand where the chirp is coming from.
    Jimmyh likes this.
  20. Jul 11, 2020 at 7:17 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Wow. You needed to replace the clutch on a 4 year old truck?
    That is crazy early.
