Throw Out Bearing replacement...do the clutch too?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoDog33, Jun 29, 2018.
  1. Jul 1, 2018 at 8:03 PM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    The TSB bearing is no better. Had mine done by Toyota under the TSB a couple of years ago and it's chirping again in less that 25k miles. Of course they only warrantied it for 12 months, ugh.
  2. Jul 1, 2018 at 8:54 PM
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    Mine was replaced with an AISIN bearing and has been fine.
  3. Jul 2, 2018 at 8:25 AM
    TacoDog33
    TacoDog33 [OP] Member
    2010 Tacoma TRD
    It is working, just doing the chirp.
    I just bought it with 70K on it, drove it home 250 miles, started a couple days after I bought it.
    That is exactly what it is. Thought it was a belt. Only goes away when clutch is depressed. Can be idling in neutral with clutch out and still chirps.
  4. Jul 2, 2018 at 8:36 AM
    vtown
    vtown Well-Known Member
    CT
    09 Access TRD OR 4x4 V6 6spd
    I wouldn’t bother fixing at this time for minor annoyance. Wait till you need the clutch done
    TXpro4X4 likes this.
  5. Jul 2, 2018 at 10:33 AM
    TacoDog33
    2010 Tacoma TRD
    Sure appreciate all the input, I'm going to wait on it for now as it is only annoying not affecting anything else. That said, am I running the risk of something major going wrong if I drive it to the point that the TOB actually goes out? Would I notice issues in shifting before it actually shits out on me? Shifts fine now.
    TXpro4X4 and Slamuel like this.
  6. Jul 2, 2018 at 12:07 PM
    Slamuel
    Slamuel Well-Known Member
    Sam
    Tacoma
    Nailed it. Same here bud. Be calling URD if it gets any worse. What happens next? What’s after the squeak? Am I in any danger letting it ride? Not gonna grenade my tranny or anything is it?
  7. Jul 2, 2018 at 12:12 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That's not even a question, yes replace the clutch since you are in there!
  8. Jul 2, 2018 at 12:20 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    I second this question, but how about like the torque converter and or as well?!?
    I'm a 6sp manual
  9. Jul 2, 2018 at 1:32 PM
    k5driver
    k5driver I hate bums
    Montana
    2009 4x4 DCSB MT SR5
    Dude I am in the exact same boat as you, I just bought my first tacoma, a 2009 6 speed 115k in the beginning of June. The dealership was near a highway and I didn't hear the chirp until I was home and thought "damn I have to replace everything!"
    I spent a good amount of time reading a ton of threads and I haven't found anyone that had something catastrophic happen. When you eventually do your clutch it sounds like the quill (part that the TO bearing rides on) will be worn so you'll want the URD sleeve kit for a nice new surface. Other than that I plan on running my chirpy bearing all the way until new clutch time. I was relieved to see it wasn't a big deal, I didn't want to drop the trans on my new/used truck! I am slightly bummed that they have this problem, but I love manuals so even if I could go back in time I'd still buy it.
    Shark18, dborrer and TXpro4X4 like this.
  10. Jul 2, 2018 at 1:48 PM
    k5driver
    Montana
    The chirp is the TO bearing intermittently hitting the pressure plate fingers. Reading the threads there are 2 schools of thought- One side says the TO bearing is never supposed to touch the PP fingers until the pedal is pushed. The other side says the TO bearing is always supposed to be in contact with the PP fingers.
    I subscribe to the latter theory because one member looked through the inspection plate on a BRAND NEW tacoma and the bearing was always spinning.
    For me the chirp was a loud and staccato, when I barely touched the clutch the sound was still there and steadier/constant but a lot quieter. I did the slave cylinder rebuild in this thread https://www.tacomaworld.com/threads/2005-tacoma-v6-clutch-slave-cylinder-rebuild.387315/
    The rebuild is cheap and not too difficult. Now the noise is steadier and constant, no change in pedal or shift feel.
    @hladun seemed to figure out the slave cylinder thing first, pretty cool
    bwanamukubwa and TXpro4X4 like this.
  11. Jul 3, 2018 at 4:39 PM
    Chris24
    Greensboro, NC
    You're lucky then. Hope it stays quiet for you.
  12. Jul 3, 2018 at 5:30 PM
    Slamuel
    Sam
    Tacoma
    odd question...
    My clutch engages/disengages fairly far out from being completely depressed.
    Is this a sign of wear?
    I know it’s hydraulic. So I’m thinking none of this matters.
  13. Jul 4, 2018 at 11:04 AM
    TacoDog33
    2010 Tacoma TRD
    That's what I'm thinking now. Like I mentioned, just want to know what kind of trouble I might get myself into if I let it go until it goes out. Not worried about it breaking down on me but what kind of additional damage could I do? Anyone have ideas/knowledge on that?
  14. Jul 5, 2018 at 3:32 PM
    Chris24
    Greensboro, NC
    I've seen that question asked often, but have never seen anyone post a story of any sort of catastrophic failure.
  15. Jul 6, 2018 at 5:22 AM
    #35
    Aerose91
    Aerose91 Well-Known Member
    Connecticut
    07 TRD Sport 4x4
    Unless there's something unique about a tacoma, your clutch wearing to the point of slippage wont hurt anything else. It's not like a timing belt where if it snaps you risk bending the valve stems
  16. Jul 7, 2018 at 2:01 AM
    #36
    casey2012
    casey2012 Well-Known Member
    mark
    yota
    none
    2012 bought new started chirping at at 30000 have 231000 now just drive they all chirp
  17. Jul 8, 2018 at 8:19 PM
    #37
    Shark18
    Shark18 Well-Known Member
    Daniel
    2007 White dbl cab Tacoma 4x4 TRD
    Mine started to chirp at 30k , now 268k later it still chirps just ignored it...I may never replace the clutch .......:yay:
  18. Aug 1, 2018 at 10:23 AM
    #38
    TacoDog33
    2010 Tacoma TRD
    Thanks for all the input! I said screw it and just turn the radio up. :cool:
  19. Aug 1, 2018 at 10:32 AM
    #39
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    Free mod! Plus adds 5 HP
    kidthatsirish and QuicksandTaco like this.
  20. May 25, 2019 at 9:01 AM
    #40
    bwanamukubwa
    bwanamukubwa Well-Known Member
    Tennessee
    Instead of upgrading the slave cylinder couldn't the clutch free play just be adjusted from inside the truck such that it always applies a small amount of force to engage the TOB since it is made to spin continuously? Does putting in a stronger spring (04313-34011) and longer push rod (31473-35060) in the SC do this differently than taking out the free play by adjusting the free play adjustment screw?
    Thanks in advance.
