throw out bearing
Discussion in 'Technical Chat' started by JOEYCHEESE, Jan 31, 2011.
  1. Jan 31, 2011 at 3:01 PM
    JOEYCHEESE
    JOEYCHEESE [OP] New Member
    JOEY
    NEW YORK
    08 SR6
    I have an 08 SR6. At 25000 miles I had the TO bearing replaced. everything seemed ok. Now 25000 miles later the chirping noise is back. Is this a common problem? What should I do? It's out of regular warranty. I think this may be covered under the powertrain warranty.
  2. Feb 2, 2011 at 6:11 AM
    huskyking
    huskyking Active Member
    Scott
    Ontario, Canada
    03 tacoma SR5 TRD
    did the chirping noise start after it was warm and when... you have foot on brake and in drive or revese???
    thx
  3. Feb 2, 2011 at 6:24 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Yes it's normal. All 6speeds will get a squeaky throwout bearing. The problem is other than PDM (an aftermarket company) Toyota has not come up with a solution, they just keep replacing it with the same defective part.
    Mine has been squeaky since the day I bought it (42k miles) and I have about 83k now and it still squeaks. Personally I think it's just an annoyance. People on here scream bloody murder and make a big fuss about it, but I have yet to see anyone have a catastrophic failure of the bearing.
    There are about 1,000,000,000,000,000 threads covering this same topic. Search!
  4. Feb 2, 2011 at 6:35 AM
    808matt
    808matt Well-Known Member
    hawaii
    15 crew cab
    i only hear it when my windows are down so by simply leaving the windows up solves my problem
  5. Feb 3, 2011 at 5:25 AM
    huskyking
    Scott
    Ontario, Canada
    03 tacoma SR5 TRD
    sounds like your little problem is quite different than mine,with my truck i get a weird rattle when foot is on brake and in drive or reverse, only after warmed up, your truck is newer than mine and obviously a throw out bearing, two different scenarios i beleive, best of luck
  6. Feb 3, 2011 at 10:25 AM
    JOEYCHEESE
    JOEY
    NEW YORK
    08 SR6
    It happens about 5 minutes after i start it cold. It happens in gear or in neutral when the clutch is NOT engaged. I called the dealer, they said bring it in. It may only need lubrication. That is what I think they did the first, I thought they replaced it. Should I I tell them I want it replaced and not lubricated or will they just do what they want.
  7. Feb 3, 2011 at 10:28 AM
    cohrmundt
    cohrmundt Well-Known Member
    Cullen
    TEXAS
    2006 TRD SPORT 4X4
    4.88 nitro gears, Detroit rear, Projector headlights, Relentless Fab custom bumpers and sliders, 6" Pro Comp suspension, all pro leafs, 37x13.5x17 toyo open country tires, method racing wheels, Flowmaster exhaust w/cutout, DTLT headers, K&N CAI, URD MAF calibrator, grillcraft grill with 30" and 20" led bars behind, windshield mounted 50" led bar, Infinity 6x9 speakers, Custom box w/MTX 7500 10"sub, MTX 1200 watt amp, blue led gauge cluster and radio mod, URD short shifter, fiberwerx fenders
    all you need is a good exhaust put on, and new speakers. Thatll fix the chirping!:D
  8. Feb 4, 2011 at 5:13 AM
    huskyking
    Scott
    Ontario, Canada
    03 tacoma SR5 TRD
    nothing is ever perfect in life, my truck looks great, drives straight and i think i will just turn up the satellite radio and not put my foot on brake, that way my noise is gone LOL, problem fixed!
  9. Feb 4, 2011 at 7:23 AM
    JOEYCHEESE
    JOEY
    NEW YORK
    08 SR6
    I think I'll take your advice.
  10. May 25, 2011 at 9:09 PM
    gofas
    gofas Well-Known Member
    Russell
    Ukiah
    4x4 Timberland Mica Access
    ImMrYo review mirror bracket.
    hell yeah!
