Throwing 2 Codes (p0441, P0455)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brandon H, May 21, 2010.
  1. May 7, 2016 at 2:45 PM
    foampile
    foampile Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    By "purge hose", do you mean the PCV hose on the drivers side of the engine, going from the cylinder cover to the intake manifold?
  2. Dec 4, 2017 at 1:03 PM
    DMCtacoma
    DMCtacoma Well-Known Member
    Brian
    Prescott,Az
    08 caged long travel preruner
    Almost everything
    For people reading this from a google search. Just had these two codes on my 08. Replacing the gas cap seal fixed it.
  3. Jun 26, 2018 at 2:46 PM
    ZiggyG
    ZiggyG New Member
    '08 Tacoma Prerunner
    bush bar, roof rack, LED lights, tail pipe, steps
    For google searchers: Had the same 2 codes on my 08. Gas cap was loose. Issue resolved.
  4. Dec 11, 2021 at 9:47 AM
    Tacoroamer
    Tacoroamer Active Member
    Atlanta
    06 Access Cab
    camper top
    My 2006 Tacoma was throwing speed error codes a couple of years ago. The south Atlanta dealer changed the speed sensors and that didn't fix it. I saw a post here about replacing the whole meter panel. I suggested they do that, they did and it was fixed. Now, it's throwing the p0445 and p0441 codes. They replaced the charcoal canister for around $400 and the purge valve. Three days later, its on again with same codes. I can recommend a little widget called the Ultragauge. I installed one several years ago in my Taco and it has proven to be very useful showing lots of diagnostic stuff. I'm going to try tightening the gas cap and clearing the codes to see what happens.
  5. Jan 1, 2023 at 8:32 AM
    SethM
    SethM Well-Known Member
    Seth
    Los Angeles ca
    2011 mgm tacoma trd sport 4x4
    3" toytec lift 285/75/17" tires
    Am having same 2 codes replaced canister(used), purge solenoid, gas cap. Smoke test showed a leak at the gas filler neck, but the holes seemed to be factory. I am completely stuck and do not know what to change next.
  6. Jan 1, 2023 at 8:50 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    Pull off the evap valve thingy that bolts on the driver side of the intake.
    Blow in it. The valve should be shut and you can't blow through it.
    If you can blow it, replace it.
    Check the hoses, probably replace them as well.
    Maybe $30 total fix.
    SethM likes this.
  7. Feb 13, 2024 at 4:31 PM
    Skatinfool
    Skatinfool New Member
    2017 Toyota trd sport
    I have both of these codes and just put a flatbed on the truck. I went to fuel up and fuel burped out of the hose near the tank. Could I have got fuel trapped in the evap line. I tightened my gas cap and check all lines and they are connected?
