throwing a p0450
Discussion in '1st Gen. Tacomas (1995-2004)' started by bry838, Sep 30, 2014.
  1. Sep 30, 2014 at 10:32 PM
    bry838
    bry838 [OP] Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Hey guys, so got the ole CEL on the way home. Code p0450... checked the vac lines and such and fuel tank has good pressure when the cap is released. So I figure its my vapor pressure sensor right?? Where's a good place to get one of these? Can u interchange them with other toyota vehicles??
    2000 2.7l manual
  2. Oct 1, 2014 at 5:21 PM
    bry838
    oregon
    Anybody!??
  3. Oct 1, 2014 at 10:21 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Follow this link to TTORA....;)
  4. Oct 2, 2014 at 6:02 AM
    bawilson21
    bawilson21 Well-Known Member
    Bryan
    WA
    00 SR5 V6 4x4 5-speed
    Rear Diff Breather Extension Deck Plate Mod 31" Destination A/T 3" Body Lift Rancho 5000 Shocks Grey Wire 7Pin Tow harness
    You might try cleaning it first with Mass Air Flow Cleaner before you replace it. I had the Intermittent P0450 code for about a year thinking it was a vacuum leak somewhere. I finally decided to clean it with some MAF Cleaner and have not had the code come up since. There was some dust on the sensor that sticks inside the air hose for me.
    There are a few threads out there that say that cleaning it is a waste of time, but it certainly wont hurt anything. Alot cheaper to try doing that first before buying a new one.
  5. Oct 2, 2014 at 7:20 AM
    bry838
    oregon
    Thanks I'll give her a shot!
  6. Oct 20, 2014 at 2:36 PM
    bawilson21
    Bryan
    WA
    So I just wanted to report that after cleaning my Vapor Pressure Sensor, I still received the P0450 code. Cleaning it may/may not have helped, but it is back. After I shut down the engine, I can hear a very faint hissing noise coming from the Air Canister. It may be a cracked hose around it. I may try dabbing some silicone over the visible cracks at the end of the hose. Of course it may be the sensor itself that is bad too. Still unsure.
  7. Oct 20, 2014 at 3:18 PM
    bry838
    oregon
    I cleaned mine and cleared the code. So far I have driven pry 500 miles with no CEL. So I assume mine will return as well...
  8. Oct 21, 2014 at 9:03 AM
    bawilson21
    Bryan
    WA
    To me it isn't a high priority issue to get this fixed. I haven't noticed a difference in power or efficiency so oh well. I'll just clear the code and run premium gas whenever i have to do my emissions.
    If anyone is going to b!tch about how im harming the environment - consider this. The Air Force regularly dumps thousands of gallons of fuel into the air when aerial re-fuelers have to land and havent dispensed all the Jet fuel from their wings. It removes the weight from the wings so they aren't bouncing off the runway during landing. Random fact :)
  9. Jun 12, 2015 at 12:48 PM
    bawilson21
    Bryan
    WA
    Still getting the CEL infrequently. Cant really determine a pattern to it but i can go months without it, then it will come back for a week or 2, then its gone for a few months. Kinda like a cold sore... Anywho, I found this in the FSM to test the Vapor Pressure Sensor, though Im not a huge fan of removing trim pieces to get to the ECU just to test this.... too lazy, but here is the page to test the Vapor Pressure Sensor for code P0450 if anyone needs it.
