Throwing Codes!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Captqc, Oct 5, 2017.
  1. Oct 5, 2017 at 10:59 AM
    Captqc
    Captqc [OP] Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Well I thought I was smarter than my Taco so I installed a front camera last night.:) It worked great but as I was driving to work this morning I noticed that my clock wasn't displayed and I now have the Check Engine and Trac Off lights lit up. :eek:Anybody have a suggestion for a good OBDII scanner? Gad I hate electrical troubleshooting!:annoyed:
    Update: In a moment of clarity I remembered that I left a diode out of the circuit to pin 2 on the 28 pin connector. Took 10 minutes at lunch to solder it in, all good now. Guess I shouldn't do mods after midnight!
    98tacoma27 and Beerpayzdabillz like this.
  2. Oct 5, 2017 at 11:36 AM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    How did you hook up your front camera?
    RIDERED67 likes this.
  3. Oct 5, 2017 at 11:38 AM
    Clearwater Bill
    Billy
    Largo Florida
    Warranty.
    Unless you've been hacking wiring of the affected items.
  4. Oct 5, 2017 at 11:40 AM
    Herniator
    Edmonton
    Codes thrown by modifying the vehicle isn't covered by Warranty.
  5. Oct 5, 2017 at 11:42 AM
    Bishop84
    Bishop84 Well-Known Member
    You likely blew a fuse, check all fuses under hood and under the drivers dash. It might clear the code with needing a reader.
  6. Oct 5, 2017 at 11:48 AM
    Captqc
    Tigard, OR
    I’ll do some troubleshooting this evening and post what I figure out.
  7. Oct 5, 2017 at 11:53 AM
    Clearwater Bill
    Billy
    Largo Florida
    Didn't I say that with my 'unless' qualifer?
  8. Oct 5, 2017 at 12:22 PM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    I don't think an obd2 scanner will help in this case since it is most likely due to a wiring issue when you set up your camera. Sure you might find something it is affecting but it isn't the real root cause.
    That being said if you still want to scan it, the big chain auto parts stores will do it for free, no need to buy a scanner just for this.
    I personally have a scanner because I get a check engine light all the time on a different vehicle I have, and I need to confirm it is still just an Evap leak. If it was just a one time use like this, id just swing by AutoZone/oreilly's.
  9. Oct 5, 2017 at 12:25 PM
    joemc
    joemc Well-Known Member
    Joe
    2017 TRD Sport Access Cab
    I picked up a bluetooth scanner off Amazon and use my android phone to read the codes on torque app. Works pretty well.
    dzkritzas, tow-coma and tonered like this.
  10. Oct 5, 2017 at 1:00 PM
    Captqc
    Tigard, OR
    See Edit up top
    Clearwater Bill likes this.
  11. Oct 5, 2017 at 1:07 PM
    Captqc
    Tigard, OR
    I used a slightly modified version of Hoange's schematic because I used a wireless transmitter and receiver.
    dzkritzas likes this.
  12. Oct 5, 2017 at 6:53 PM
    Captqc
    Tigard, OR
    I’m thinking that I’d like to have a scanner for future use. Any suggestions on brands and features are appreciated.
  13. Oct 5, 2017 at 8:12 PM
    Jeff1795
    Jeff1795 Well-Known Member
    Panama City FL
    LT 2017 TRD Sport 4x4 Access Cab 6-Speed
    Snap on verus! It does electrical troubleshooting
  14. Oct 5, 2017 at 8:24 PM
    Captqc
    Tigard, OR
    Thanks, I’ll check it out.
    Update: holy crap! Those are spendy! :eek: Next suggestion please!:wave:
  15. Oct 5, 2017 at 8:28 PM
    erok81
    erok81 Well-Known Member
    Imposter
    Where's the write up man! I need to do this to mine!
  16. Oct 5, 2017 at 8:32 PM
    Herniator
    Edmonton
  17. Oct 5, 2017 at 10:13 PM
    Captqc
    Tigard, OR
    Herniator[QUOTED] likes this.
  18. Oct 5, 2017 at 10:22 PM
    My Truck
    My Truck Well-Known Member
    Bay Area, CA
    2016 SR DCSB 4x4 Super White`
    Any more details please? Have Hoange's harness and would like to incorporate a front camera. Link to the unit you purchased?
  19. Oct 5, 2017 at 10:26 PM
    Captqc
    Tigard, OR
    Sorry, I didn’t really think to document the process. Here’s a bit more info, I removed the iQ charger switch and replaced it with the camera switch. I took power off the 12 volt outlet to power the camera switching relay. I used an Audiovox ACA200W camera wired up to the wireless transmitter under the hood and tucked the wireless receiver and switching relay behind the dashboard.
