throwing together a 4inch lift
Discussion in 'Suspension' started by tromo, Mar 15, 2010.
  1. Mar 15, 2010 at 6:55 PM
    tromo
    tromo [OP] Member
    virginia
    4x4
    what do you guys think of 1. bilstein 5100s, 2. toytec front coil springs, 3. 2.5" coil spring spacers, 4. 2.5 rear leafsprings, 5. 1.5in rear block...also some other little things like swaybar ends and stuff...im just not sure i can use the coil springs and the spacers with the shocks....any input would help.
    thanks.
    tromo
  2. Mar 15, 2010 at 9:32 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    A. you cant get over 3 inches without a drop bracket
    B. it is extremely dangerous to stack lifts coils shock and spacer
    And welcome to TW:wave:
  3. Mar 15, 2010 at 9:58 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    A. Yes
    B. Yes
    This setup won't work in the front. If for some reason it did it would be a HORRIBLE ride and cause all kinds of problems: won't ever be able to align properly, wear out CVs super fast, etc. 3" is easy, after that you'll need alot more $$$tuff.
    Setup will work n the rear tho. You can go as high as you want in the back but you'll have to get a custom driveline after 4" probably.
    Look into long travel kits for the 4", or go for a drop-bracket 6"
  4. Mar 16, 2010 at 3:01 AM
    tromo
    tromo [OP] Member
    virginia
    4x4
    ok i thought i read something about the coils and spacers not working together before...thanks
  5. Mar 16, 2010 at 8:40 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    You can do a mild 3" suspension lift with a 1" BL. Other then that...DB kit like FT or PC.
