Thrown PO171 code help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Phearson, Apr 26, 2012.
  1. Apr 26, 2012 at 4:15 PM
    Phearson
    Phearson [OP] Taco or Die
    Brad
    Gresham OR
    1996 SR5 Tacoma. 33x10.5 Kevlar 3in lift
    So im getting a po171 and a PO420. PO420 is the cat going bad.. but the PO171 is to lean. Now my question is is it lean because of a MAF or an 02 sensor? ORR injectors? I didnt get a direct problem so im kinda up to guess.
    On another topic i might just throw a test pipe in but how could i bypass an 02 sensor or will i have to live with the CELL on always?
  2. Apr 27, 2012 at 12:17 AM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    i would try cleaning the MAF first with the proper maf cleaner. i had the p0171 code a while back and cleaning the maf helped.
  3. Apr 27, 2012 at 5:08 AM
    theGastone
    theGastone New vehicle/Tacoma *****
    Ian
    Leesburg, VA
    '97 Standard
    You may not actually have the P0420, but that it's being caused by the P0171. My check engine light has the P0171 on and I've found where the sensor is etc. But it's not that important of a fix for me, so I just reset the codes for now. You may just have to replace the bank 1 sensor to fix both problems.
  4. Jun 4, 2012 at 8:54 PM
    JakeInGrayTacoma
    JakeInGrayTacoma Active Member
    Jake
    SoCal Mtns
    95 4x4 gray tacoma
    Get back up to snuff cuz it wasn't maintained. I got xm radio in it.
    Where is the bank 1 sensor? I got a P0170 reading this afternoon when I hooked up the obd2 to my truck. Discovered it was the "fuel trim bank 1" all hoses are connected, and I sprayed out the MAF sensor. What do I do to get the check engine lite off?
  5. Jun 5, 2012 at 7:03 AM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
  6. Jun 5, 2012 at 11:25 AM
    98tacoma27
    Ben
    Not Beech Creek
    That sensor is in front of the cat on the driver's side in the exhaust pipe.
  7. Jun 5, 2012 at 11:29 AM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    So ive had the P0171 "system too lean" code for a long time now. Ive cleaned the maf several times, changed air filter, cleaned throttle body and still showing the code. I replaced both o2 sensors last year. Could the pre-cat o2 have gotten fouled? Can you clean the o2 sensors with a sensor clean?
  8. Jun 5, 2012 at 11:33 AM
    98tacoma27
    Ben
    Not Beech Creek
    It could be any of these...
    • Air intake (hose loose)
    • Fuel line pressure
    • Injector blockage
    • Heated oxygen sensor malfunction
    • Mass air flow meter
    • Engine coolant temp. sensor
  9. Jun 5, 2012 at 11:39 AM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
  10. Jun 5, 2012 at 11:42 AM
    98tacoma27
    Ben
    Not Beech Creek
    They forgot to mention exhaust leak too.
  11. Jun 5, 2012 at 11:49 AM
    medic2230
    Murph
    Bama! Roll Tide
    When the 99 4runner did it toyota started with the MAF sensor and got it. The tech had been working on toyota's for 30 years. He said that was it before he looked at it. Runner threw the same code. YMMV
