Throwout bearing chirp-TOB not disengaging?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GreyDongle, Jul 3, 2020.
  1. Jul 3, 2020 at 7:55 AM
    GreyDongle
    GreyDongle [OP] Active Member
    2008 Indigo Ink PreRunner SR5
    I have the ol 6spd chirping tob, its driving me mad! The clutch flywheel and bearing was just put in last july and only has around 10k on it and the chirp is back and badder than ever. Going with a suggestion from another forum I took my dustcover off and carefully used a super high temp grease on the input shaft snout behind the TOB, well that didn't work, after taking it off again and looking, with the clutch pedal not being pushed, the TOB is pressed against the fingers of the pressure plate. I'm wondering if that's my culprit, if I'm not mistaken, at pedal out, the bearing should not be engaging anything, is there adjustment in the slave cylinder? Is the slave cylinder shot?
  2. Jul 3, 2020 at 8:01 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Could be the slave cylinder or a bent TOB fork. Does the TOB touch fingers with slave removed?
  3. Jul 3, 2020 at 8:09 AM
    GreyDongle
    I'll have to get under and pull it on Sunday next day I'm off, but I was figuring the return spring could be causing it to not pull the piston back in
  4. Jul 4, 2020 at 11:50 PM
    Jason J
    Jason J Well-Known Member
    oregon
    08 tacoma 4x4
    The TOB is going to contact the fingers at all times as it should. If you haven't put in the updated slave cylinder you could try it. The updated one has a longer plunger and stiffer spring which both help to keep more pressure against the fingers on the pressure plate.
  5. Jul 5, 2020 at 9:25 AM
    GreyDongle
    I already ordered the rebuild kit after reading through another thread, I've not torn into too many manual vehicles but most I've seen the TOB doesn't actually touch anything with the pedal up. Kinda wierd but I'm hoping rebuilding the cylinder will at least hush the squeak a little
  6. Jul 5, 2020 at 9:40 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yeah it does. Mine has the noise and has had it for the last 120K miles generally only when the weather is cold. Because it has no adjustment the slave cylinder must remain full of fluid or it would not disengage the clutch because there would be too much free play.
  7. Jul 30, 2020 at 1:46 PM
    TacoNH
    TacoNH Well-Known Member
    Nü Hampshire
    07 Blue Tacoma 4.0/6speed
    887s, 5100s, Light Racing UCAs, Nitto 285s, Leer Cap.
    Could you post a link where you got the rebuild kit? I believe it is time to rebuild mine.
  8. Jul 30, 2020 at 2:00 PM
    GreyDongle
    Part number is 04313-34011, got mine off Amazon, but look around you may be able to get it cheaper
  9. Aug 1, 2020 at 10:11 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    I would recommend 04313-34011 and 31473-35060 (or alternatively 31470-35181 for the complete assembly) when doing this. The spring is stiffer and the pushrod slightly longer to ensure that there is enough force keeping the release bearing pressed against the pressure plate.
    Jeff
