Throwout Bearing or No?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Trident904, Dec 6, 2018.
  1. May 6, 2024 at 10:48 AM
    #61
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Maybe this little POS fixed itself? Ha
    https://youtu.be/dzHOr7Wd5Bo?si=c9_d9MAHXhLNYMxU
    It did rain all night so I’m guessing all this moisture helped.
    Well, let’s see what happens in next few days.
    Edit: just took it for a short drive and it squeaks. Noise gone when clutch is depressed.
    Had this truck for 6 years so that’s the first issue, not terrible but at only barely 40k miles it’s way too soon.
  2. May 6, 2024 at 6:14 PM
    #62
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    if you find a way to snake in there to grease, be sparing with it and use a high moly grease. When the grease dries up the moly will remain and act as a dry lube.
    I guess another way to verify your noise would be to sneak in around the fork or something and either spray some graphite spray in there or lithium grease in a can. Neither i've found contaminate the friction material
    .... if it could safely be done with the engine rolling it would also throw off any overspray... not saying to do that because it's dangerous and you could burn yourself unless the engine were cold when you started off but, just a thought.
    Junkhead[QUOTED] likes this.
  3. May 7, 2024 at 7:36 AM
    #63
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Really appreciate it man. I’ll giver this a try in next few days.
    Im doing some junk removal jobs today and tomorrow so gonna be towing heavy, curious if the squeaking will get louder.
    joba27n[QUOTED] likes this.
  4. May 7, 2024 at 7:45 AM
    #64
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I subbed! Good luck on the repair lol.
  5. May 8, 2024 at 11:14 AM
    #65
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Thank you sir!
    Lt. Dangle[QUOTED] likes this.
  6. May 8, 2024 at 11:17 AM
    #66
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Didn’t have time to lube or adjust anything yet.
    I did 2 dump runs yesterday. The first one the trailer GVWR was at 3650#, second was around 3k.
    Well what do you know, the squeak went away haha. I’m sure it will come back but I’m not too worried about it for now. I wil have some time this weekend so I’ll lube and adjust free play if needed.
    Lt. Dangle likes this.
  7. May 25, 2024 at 9:53 AM
    #67
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    UPDATE:
    Throw out bearing “fixed” itself. Absolutely no noise. For now anyway.
    Thanks taco!
    Lt. Dangle, doublethebass and joba27n like this.
