Throwout bearing
Discussion in '1st Gen. Tacomas (1995-2004)' started by saweetlou, Aug 25, 2010.
  1. Aug 25, 2010 at 10:43 AM
    saweetlou
    saweetlou [OP] Well-Known Member
    Guelph Ontario
    TRD Stepside
    2in Skyjacker
    I had my clutch (pressure plate TO bearing and pilot bearing all new) replaced about 2 months ago and Im guessing its my throwout bearing squeaking whenever the clutch is not engaged, it seems to be progressively getting louder. This is really starting to annoy me. Do I have any options aside from replacing the bearing.
  2. Aug 26, 2010 at 2:25 PM
    offroadTRD
    offroadTRD Well-Known Member
    Dinwiddie County, Virginia
    2000 Tacoma V6 SR5 4x4 TRD- Fabtech
    Fabtech 3" adjustable coil-over system, Alcan 8-leaf spring pack, Fabtech 3" body lift.
    Don't worry, you're not the only one with this issue. I replaced my clutch, pressure plate, throw out bearing, and pilot bearing also with the same results as you. My throw out bearing still squeaks to this day even with it being brand new. I'm not even gonna worry about mine. When my clutch goes out again, I'll repeat the process.
