throwout bearing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by easye515, Mar 17, 2019.
  1. Mar 17, 2019 at 9:00 PM
    easye515
    easye515 [OP] Well-Known Member
    2016 Tacoma TRD Offroad 6 speed manual.
    MOC221_ likes this.
  2. Mar 17, 2019 at 9:19 PM
    Shellshock
    Iowa
    @Trident904 can tell you all about the clutches and fly wheels
    Trident904 likes this.
  3. Mar 17, 2019 at 10:45 PM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
  4. Mar 18, 2019 at 2:47 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    How many miles on the truck?
    I get some noise from my TOB when it's well below freezing, but never when warmed up.
  5. Mar 18, 2019 at 3:23 AM
    easye515
    63,000. I am kinda surprised its going out already, but at the same time, not shocked at all. I have always thought the clutch was not always 100% but the two times I brought it up at my service appointments, I get the "performs as expected" reply.
    MOC221_ likes this.
  6. Mar 18, 2019 at 3:27 AM
    MOC221_
    Frank
    Ah ok, you've got quite a bit more miles on yours than I have on mine (46000 km). Still, you're right - it shouldn't be going out that soon.
    Other than the odd noise, I get some chatter when the clutch is damp, but that's normal.
    Let us know how everything goes please.
  7. Mar 18, 2019 at 3:33 AM
    easye515
    I noticed it after a 4 hour drive to Iowa last night, and then spent 30 minutes driving around listening to it, so it definitely isn't an issue that goes away after being warmed up. I also got super acquainted with my squeaky leafs last night too. lotta noises coming from the truck these days, hahahah.
  8. Mar 18, 2019 at 5:03 AM
    Skidog1
    Skidog1 Well-Known Member
    Chicagoland
    2016 Black TRD 4x4 Sport DCLB
    I'm not a mechanic but I believe a throw out bearing only moves when the clutch is depressed. You would not here it driving around unless you depressed the clutch pedal.
  9. Mar 18, 2019 at 5:48 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    This. If it's making noise when the clutch pedal is not depressed, then it's the pilot bearing. If it's noisy when you press the clutch pedal, then it's the throwout bearing.
    Like @MOC221_, my pilot bearing squeals really bad when the weather is below freezing, but it goes away once the transmission warms up, or if I depress the clutch pedal.
    Silentshredr and MOC221_ like this.
  10. Mar 18, 2019 at 5:54 AM
    MOC221_
    Frank
    I'm no expert on TOBs, but I do know what you're talking about WRT the pilot bearing/bushing that is normally in the ass end of the crank.
    In the case of the 3rd gen 6-speed for V6 trucks (RC-62F), there is no pilot bearing and no snout on the end of the input shaft. I know, like WTF? It's in the service manual.
  11. Mar 18, 2019 at 5:55 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    I’ve read that the URD Stage 2 clutch and heavy flywheel are a better combo for the 3rd Gen than the stage 3
  12. Mar 18, 2019 at 5:59 AM
    MOC221_
    Frank
    When Trident shows up, he'll set us all straight WRT TOB symptoms (as his pretty much grenaded) and which URD clutch/flywheel he's running.
  13. Mar 18, 2019 at 6:27 AM
    ShirtTucker
    2017 V6 Sport AC MT
    Lots-o-stuff
    No shit? I'll have to check the manual. So what the hell is squealing when the clutch is at rest, the throwout bearing?
    MOC221_[QUOTED] likes this.
  14. Mar 21, 2019 at 5:54 PM
    easye515
    So after a day it stopped whining. Weird. but I am still going to keep looking into the new clutch. The stage 2 and flywheel upgrade look appealing.
