Thud going over speedbump after lift
Discussion in 'Suspension' started by Geo Taco, Jan 12, 2012.
  1. Jan 12, 2012 at 6:28 PM
    Geo Taco
    Geo Taco [OP] Well-Known Member
    Justin
    Lafayette, CO
    2012 Subie Impreza
    Black Softopper
    Ok,
    At one point I found a thread talking about this exact problem, but for the life of me I cannot find the thread. I know, search... I have been and I'm not finding anything.
    Onto the issue:
    I have a 2011 DCSB that I just lifted with and OME kit.
    OME 9000/885 front
    OME n182 rear w/ 1.5" aal
    ToyTec sway bar relocation kit
    When going over a speedbump over 20 mph I hear a thud. I heard this before I put the sway bar relocation kit on and figured that it was the sway bar hitting the spring perch, but even with the kit it still makes the sound. These are relatively low/long type of speedbumps. I have also checked both front uca's to see if they are contacting the spring at full droop and I can fit just about my entire hand between the uca and coil.
    Any thoughts?
    Thank you for your input.
  2. Jan 12, 2012 at 6:32 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    probably the shock topping* out, happened to me ALL the time when I had the OME 3"
    *topping out sorry, overextending
  3. Jan 12, 2012 at 6:34 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    can you determine if its from the front or rear?
  4. Jan 12, 2012 at 6:35 PM
    Geo Taco
    Justin
    Lafayette, CO
    2012 Subie Impreza
    Black Softopper
    Shock bottoming out... really, I guess I thought there would be a little more travel. I guess that the only "fix" is to not fly over the speedbumps, what fun is that
    It is funny that this didn't occur with the stock off road bilsteins.
  5. Jan 12, 2012 at 6:35 PM
    Geo Taco
    Justin
    Lafayette, CO
    2012 Subie Impreza
    Black Softopper
    I am almost positive that it is the front, you can hear it as the front goes over, before the back makes it over the bump.
  6. Jan 12, 2012 at 6:39 PM
    Geo Taco
    Justin
    Lafayette, CO
    2012 Subie Impreza
    Black Softopper
    08pretaco, I followed you.
  7. Jan 12, 2012 at 6:41 PM
    08pretaco
    az
    Those were not preloaded either. I mean thats what I experienced, does not necessarily mean thats what you are experiencing. Have you pulled extended your front suspension and checked for any metal on metal contact such as UCA on coils or anything like that?
  8. Jan 12, 2012 at 6:42 PM
    Geo Taco
    Justin
    Lafayette, CO
    2012 Subie Impreza
    Black Softopper
    I tried to pull the suspension down, maybe I just didn't pull hard enough. Which could be that its the uca. I've been eyeing some LR uca's so this may be the push to go ahead and get them.
  9. Jan 13, 2012 at 12:13 PM
    Geo Taco
    Justin
    Lafayette, CO
    2012 Subie Impreza
    Black Softopper
    Ok, I think I found the culprit. I jacked the truck up, took the wheels off and found a small spot on the passenger coil where I think the uca is hitting. I am mobile at the minute and will post pics at some point. When looking at the coils the driver's side bottom end of coil it facing out. On the pass side the bottom end of the coil is facing in (towards the engine).
    So, new question: will LR uca's solve this problem? Do they have more clearance btwn the uca and the coil when suspension droops?
  10. Jan 13, 2012 at 12:15 PM
    98tacoma27
    Ben
    Not Beech Creek
    No, just turn turn the coil
  11. Jan 13, 2012 at 12:19 PM
    Geo Taco
    Justin
    Lafayette, CO
    2012 Subie Impreza
    Black Softopper
    I'm guessing that would require a spring compressor. Just disassemble coilover and rotate spring, then reassemble. I purchased these assembled from ToyTec, hoping that I wouldn't have to deal with that.
  12. Jan 13, 2012 at 12:20 PM
    98tacoma27
    Ben
    Not Beech Creek
    Yep.
  13. Jan 13, 2012 at 12:21 PM
    Geo Taco
    Justin
    Lafayette, CO
    2012 Subie Impreza
    Black Softopper
    Also, just to be sure... Would I need a new alignment? I'm guessing no b/c it shouldn't change any geometry.
  14. Jan 13, 2012 at 12:22 PM
    98tacoma27
    Ben
    Not Beech Creek
    Correct
  15. Jan 13, 2012 at 12:22 PM
    Geo Taco
    Justin
    Lafayette, CO
    2012 Subie Impreza
    Black Softopper
    Thanks 98tacoma27. The help is appreciated.
  16. Jan 13, 2012 at 12:23 PM
    98tacoma27
    Ben
    Not Beech Creek
  17. Jan 20, 2012 at 3:05 PM
    Geo Taco
    Justin
    Lafayette, CO
    2012 Subie Impreza
    Black Softopper
    Fast forward a week or so.... Go to Autozone, rent spring compressor... Get home, open up the storage bin underneath seats where I keep the key's for the stupid trd lug nut set and....... I can't find it anywhere....Gaaaaahhhhhhhhh!!!! Just wanted to vent a little.
  18. Jan 21, 2012 at 12:44 PM
    Geo Taco
    Justin
    Lafayette, CO
    2012 Subie Impreza
    Black Softopper
    Lug nut situation solved. Got the coil spun 180 deg. and the noise is still there over speedbumps. Which is a little bit of a bummer after about 2 hrs. worth of work. At this point the only thing I can think of is what has been stated above as over extension of the shock...
  19. Jan 21, 2012 at 9:34 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    You know I have the same type of problem except that it's coming from the rear. Happens every time I go over a bump and for the life of me I can't figure it out. Are you sure its not coming from the rear? I think it my bump stop or has something to do,with it or the dakars.
  20. Jan 22, 2012 at 5:35 AM
    Geo Taco
    Justin
    Lafayette, CO
    2012 Subie Impreza
    Black Softopper
    I am gonna go out on a limb and say that I'm positive its from the front. The speed bumps here are the perfect size where you can feel the front go over the bump before the back has hit the bump at all. its a bit frustrating.
