Thud in rear of '13 over sharp bumps.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MilesToEmpty, Jan 23, 2015.
  1. Jan 23, 2015 at 12:36 PM
    MilesToEmpty
    MilesToEmpty [OP] Well-Known Member
    Charles
    Frederick Co, MD
    '13 Baja TX
    Wheelers Progressive AAL, Firestone RideRite airbags.
    So Im stumped, and Toyota can't seem to duplicate it. When i hit a sharp bump in the road, a bridge gap, etc, I get a thud that sounds like its around the passenger backseat to the rear wheel area. Ive checked things over and don't see anything lose, and I get no noise when jumping in the bed. \
    Toyota said they couldn't duplicate it when driving it around the dealer lot, so i have a feeling I'm going to have to go drive the tech around and be like "that, did you hear that?" "no? let me find another bump."
    It's not a clunk, but it sounds like there's a rubber block so something bouncing in the bed ever so slightly... I have the bfg a/t tires that come factory (TX Baja) and the baja factory suspension. The tires make a distinct "thud" of "oomph" noise when hitting bumps. The passenger rear is considerably louder can be heard over the tires impacting.
    Its been doing this for the past 8-10k miles, currently at 21k miles.
  2. Jan 23, 2015 at 3:24 PM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    My truck does it too (2012). I'm pretty sure it's the spare tire.
  3. Jan 23, 2015 at 5:00 PM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Spare tire. Tighten until you think you'll break the spare tire lift then turn another 1/8 of a turn.
  4. Jan 23, 2015 at 5:14 PM
    tacoma steve
    tacoma steve Well-Known Member
    NH
    2012 TX Baja
    Just brought my 2012 Baja in for this. Mine was the rear drivers shock, but I was able to duplicate it by jumping in the bed. They are changing the shock under warranty.
  5. Jan 23, 2015 at 7:28 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    It's not the bump stops hitting the frame?
  6. Jan 24, 2015 at 8:19 AM
    MilesToEmpty
    Charles
    Frederick Co, MD
    '13 Baja TX
    Did you actually jump in the bed, or just stand in it and shake the truck?
    Ill check my spare, but if I hit a small pothole on the driver side it sounds normal, passenger side I get that double thunk (noise then tire or vis versa)
  7. Jan 24, 2015 at 8:25 AM
    tacoma steve
    NH
    2012 TX Baja
    Actually jumped in it. I had someone else jump in the bed and felt around under truck and when I grapped the shock I could feel it. But shock wasn't loose. Dealer shock has internal damage but they had to order shock so gets changed next week.
  8. Jan 24, 2015 at 9:28 AM
    devkurf
    devkurf Member at Large
    midwest
    You can check and make sure one of your bed bolts hasnt backed out. Lift up on each of the four corners of the bed independently, and if one has backed out a little it would thump over bumps.
  9. Jan 26, 2015 at 1:21 PM
    MilesToEmpty
    Charles
    Frederick Co, MD
    '13 Baja TX
    Ill give these three things a check once it stops snowing.
  10. Feb 16, 2015 at 8:55 AM
    MilesToEmpty
    Charles
    Frederick Co, MD
    '13 Baja TX
    Well Ive been driving the Prius until last weekend so I hadn't really gotten a time to look or listen to the truck.
    When I backed out of the driveway I had a loud, as in it startled me, clunk come from the rear of the truck.
    When i got to work I jumped in the truck bed and jumped and you can hear a quiet thud-like noise come from the rear passenger side.
  11. Feb 16, 2015 at 11:37 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Pray Tell ??
  12. Feb 16, 2015 at 3:06 PM
    devkurf
    midwest
    did you lift up on each corner of the bed to see if there is play in the bolts that hold the bed down?
  13. Feb 19, 2015 at 6:19 AM
    MilesToEmpty
    Charles
    Frederick Co, MD
    '13 Baja TX
    Ive picked up on all 4 corners of the bed and don't feel anything strange or hear anything.
  14. Feb 19, 2015 at 7:17 AM
    Canufixit
    New England
    any chance it's the tailpipe / exhaust system?? Bent/moved/broken hanger?
    Can you get someone to jump in the bed and recreate the prob while you get underneath?
  15. Mar 10, 2015 at 6:57 AM
    MilesToEmpty
    Charles
    Frederick Co, MD
    '13 Baja TX
    Well dropped the truck off on Saturday. They are having a regional tech come out to see what is going on and I should have it back in a week. This is to resolve my thud and metal clunk in the rear, and a drivetrain vibration in the front end.
    Not bad for a truck that has less then 25k miles and has never been offroad...
