THUD/THUMP Noise tacoma 2023
Discussion in '3rd Gen. Tacomas (2016-2023)' started by joshhhh, Oct 26, 2023.
  1. Oct 26, 2023 at 1:32 PM
    joshhhh
    joshhhh [OP] Member
    Joshua
    TACOMA OFF ROAD DBL CAB 2023
    NONE
    Hi ya'll, Hope everybody's doing great! just reaching out for possible suggestion to locate the issue im having with my truck. I'm driving a 2023 tacoma dbl cab 2023 off road currently sitting at 17,000km. so I've noticed around 8,000km There is a delayed thud/thump sounds that i can hear and feel in driver side when ever i do a abrupt stop. it goes like break, pause, thud (most often while im parking my truck, you know when trying to park you go back and fort with hitting breaks) I also noticed recently since it got colder last couple of weeks (BTW im from canada, so winter can be really cold) thud is more often like it happens every day now. brought truck to the dealer twice when weather was warmer, ofcours when the truck is there the issue wont show up. so they said try to do some more observation. Any suggestion what would cause that sound.
    Thank you in advance.
    -Josh
  2. Oct 26, 2023 at 1:37 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    to help narrow done further,: is the thud after you let off the brake? Could be shoes or pads not sliding/moving smoothly, check brakes to see if they need cleaned and lubed.
    Stevie17 and HondaGM like this.
  3. Oct 26, 2023 at 1:44 PM
    joshhhh
    joshhhh [OP] Member
    Joshua
    NONE
    after pressing the break and the truck is completely stopped. it goes like, i hit the break, car stops, mili seconds delay, then thud sound (foot still on break).
    Thank you
    josh
  4. Oct 26, 2023 at 2:05 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    hmmm, makes me think it is not brake related.
    If you are parking and bouncing off the parking pawl (or whatever it is called) in the transmission, this is not good practice. Try easing off the brake gently and see if that helps.
    Sorry, I am out of ideas. Noises over the net (especially W/O video) is tough.
  5. Oct 26, 2023 at 2:21 PM
    joshhhh
    joshhhh [OP] Member
    Joshua
    NONE
    i mean like in tight spaces backing up from a parking spot hitting the break and after truck stopped thats the time it thuds. i Tried breaking very slowly its working during warmer weathers, like the thud appears just once in a while. then when it got colder it is happening more frequent. I am no car mechanic. pls pardon my explanation :)
    but i got it book in the dealer hopefully it thuds that time.
    and i'll try to film it
    Thanks you,
    Josh
    Stevie17 likes this.
  6. Oct 26, 2023 at 2:22 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    You described a thud when parking, going from forward to reverse.. this is most likely driveline clunk. There is play in the drivetrain and this can cause a clunk when changing directions. This noise is amplified by the hollow driveshaft tube. It's more noticeable on inclines while switching directions.
  7. Oct 26, 2023 at 2:22 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome To TW...I have a 23 that makes a sound like that every morning..but after the first pop sound it doesnt do it anymore till the next morning...
  8. Oct 26, 2023 at 2:28 PM
    joshhhh
    joshhhh [OP] Member
    Joshua
    NONE
    not exactly. i experience the thud sound after i press the break and the car stopped both in reverse and drive. Reverse or drive (while trying to park in a parking spot) after hitting the break. truck stopped. mili second delayed, then thud sound.
  9. Oct 26, 2023 at 2:32 PM
    joshhhh
    joshhhh [OP] Member
    Joshua
    NONE
    yeaaa, same here 98% of the time now thuds is present in the morning or cold start.
    did you ever brought it to the dealership to be looked at?
    Stevie17 and HondaGM[QUOTED] like this.
  10. Oct 26, 2023 at 2:35 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Oh no...Im not letting those Monkeys touch my truck..ive tighten every bolt on it so far ,but planning on putting some chassis ears on it soon.
    Mine sounds like its coming from the right front area
  11. Oct 26, 2023 at 2:36 PM
    CVCV
    CVCV 3rd Toyota Truck
    Tacoma 2022 3.5L DCSB TRD OR 4x4
    First, check the storage areas under and behind the seat to make sure it is not cargo related.
    Then have the mechanic drive it in the morning when it is cold. Sounds like suspension might be funky.
  12. Oct 26, 2023 at 2:55 PM
    Glaese
    Glaese Unknown Member
    Country of Texas
    17 Sandy Taco Ltd
    I would agree with speedfreak
  13. Oct 26, 2023 at 4:32 PM
    turbosnail
    turbosnail Well-Known Member
    Pa
    18 dbl cab sr5 v6 4x4 , 1985 turbo sr5 pick up
    Good ideas being offered up here , also check your spare tire is tight and the chain is tight , also believe it or not , a half tank of gas can make a thump sound when moving back and forth , sounds crazy , but it’s a process of elimination .. you’ll find it
  14. Oct 26, 2023 at 5:16 PM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    My 2022 did exactly what your describing dealer had field tech look at it and check everything. Everything checked out and was told nothing they could do about it. Was just another quirk of that particular truck. It seems each of these tacomas have their own personality and quirks
  15. Oct 26, 2023 at 5:51 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Random idea - make sure the battery hold down is tight. :notsure:
  16. Oct 27, 2023 at 7:35 AM
    joshhhh
    joshhhh [OP] Member
    Joshua
    NONE
    Appreciate everyones input and suggestions! I'll try do check them and give everyone an update once i done it.
    Thanks!
  17. Oct 28, 2023 at 1:07 AM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Water bottle under seat rolling forward and hitting front seat bracket. Ex-wife paid dealer to find this out.
    Chew likes this.
