Thud when coming to a stop
Discussion in '3rd Gen. Tacomas (2016-2023)' started by odinsbro15, Nov 28, 2017.
  1. Nov 28, 2017 at 1:48 PM
    odinsbro15
    odinsbro15 [OP] Well-Known Member
    Eric
    LOS ANGELES CA
    2016 Gray Tacoma trd offroad DCSB
    ROUGH COUNTRY FRONT 2 INCH LEVEL KIT, TINT, DIPPED RIMS, DITCH LIGHTS, CUSTOMER REAR FACING LIGHT, INTERIOR MATS
    i have a consistently inconsistent problem... a few times a day (random times of day with weather 50+ degrees) my truck will feel and make a noise like a bowling ball is rolling from my tailgate to the head of the bed and THUD and jostle like a pallet shifted and hit the front.... theres nothing loose in my truck bed.
    any suggestions would be appreciated.
    Boneretreiver likes this.
  2. Nov 28, 2017 at 1:49 PM
    CaptainAwesome
    CaptainAwesome Well-Known Member
    Calgary, Alberta
    Sure it's not a dead body?
    suaveflooder and TXpro4X4 like this.
  3. Nov 28, 2017 at 1:50 PM
    odinsbro15
    Eric
    LOS ANGELES CA
    pretty sure... i got rid of it a while back o_O... jkjk but in all seriousness its anoying
  4. Nov 28, 2017 at 1:52 PM
    Ct03si
    Ct03si Well-Known Member
    connecticut
    2017 dcsb OR black
    i have had the same thing happen, it seems to be when the stop is more abrupt mostly.
    Tac0Joe and remgu2000 like this.
  5. Nov 28, 2017 at 1:54 PM
    Adventurous
    Adventurous Well-Known Member
    Colorado
    15 DCLB SR5
    The slip yoke in the driveshaft can make a similar sounding clunk as the truck comes to a rest. Annoying, but not an undocumented issue. You should be fine, though if it really bothers you you can find a way to lube that connection up.
  6. Nov 28, 2017 at 1:54 PM
    Hoangde
    Hoangde Well-Known Member
    Down shifting issues ... Mine had same problem...Brought back to dealer, complained and got T-SB-0077-16.
    Nowadays, only happen one or two times a week :bowdown:
    odinsbro15[OP] likes this.
  7. Nov 28, 2017 at 1:58 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Trunk (box) monkey. He's gonna be pissed at feeding time. Use PPE on your head and groin.
    Dirty Harry likes this.
  8. Nov 28, 2017 at 1:58 PM
    Khakiman
    Khakiman Well-Known Member
    2017 Black Tacoma 4X4 Double Cab TRD Sport
    Front Grille, Step Bars, Tinted Windows, Tonneau Cover, Wheels, Tires, Roof Racks, Mud Flaps, Led Fog Lights, Mob Armor Phone Mount, Console Organizer, Pioneer AVIC 8200 NEX Radio/GPS,
    Mine did it a lot for about the first 2K miles and since then its been much better.
  9. Nov 28, 2017 at 2:08 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    +2 for the slip yoke...!! No Joke...!! Typical lack of grease by Toyota..... If it really bothere you, remove the drive shaft and grease it... better yet..... While it's off install a zerk fitting....!!!!No more freakin' issues ....!!
  10. Nov 28, 2017 at 2:30 PM
    Dawnpatrol
    Dawnpatrol Well-Known Member
    PNW
    Yep, my 2017 has experienced this. Not often but enough for me to shout WTF? Great advice on the yolk slippage. Going to have this lubed before my warranty expires.
  11. Nov 28, 2017 at 2:56 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    The bowling ball feel might be a slightly pressurized slip joint. Overgreasing could make it worse. Needs a relief hole...maybe.
    When you decelerate, the pinion dives down, the driveshaft lengthens at slipjoint and springs load up. When the springs unload, the pinion rises and driveshaft shortens. In your case the, latter is happening adruptly.
    There's a couple other less evasive things you can try before attacking the slip joint; they address the loading and unloading of the spring. Put 300-400 lbs over the rear axle and/or reinforcing the main leaf with additional clamps between the main hanger and axle.
    At least then you'll know if it's the springs or the slip joint is the real problem.
    Any mods? Lift block, perhaps?
    over60 likes this.
  12. Nov 28, 2017 at 6:23 PM
    RBaptist
    RBaptist Well-Known Member
    Newnan, Ga
    2017 TRD Sport - Magnetic Grey
    @splitbolt
    I haven't been able to find it, but is there a write up on exactly where to drill that relief hole and where to add a zerk for future greasing? I have a 2017 TRD Sport 2WD (no zerks). No lift, etc, but I also have a vibration when decelerating that the dealer can't figure out. I may have to do it myself or go to an independent shop that does drive shafts.... but would be nice to have a confirmed location for those things from someone that's done it.
    Thx!
  13. Nov 28, 2017 at 7:01 PM
    splitbolt
    NW Arkansas
    Vibe on decel; no thud? Again, that sounds like the pinion diving due to the weak springs.
    Besides, drilling a hole and installing a zerk probably has to go do a driveshaft shop for balancing anyway.
    I recommend reinforcing the leafs like I described previously; see how that works first.
  14. Nov 28, 2017 at 7:14 PM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    Sounds like classic axle wrap. 2nd Gen issue carrying over to our 3rd Gens. I have it too, just do a search on here.
    betoman and splitbolt like this.
  15. Nov 28, 2017 at 7:42 PM
    RBaptist
    Newnan, Ga
    @splitbolt. Will do - I’ll try spring clamps first.
  16. Dec 18, 2017 at 8:07 PM
    betoman
    betoman Well-Known Member
    Roberto
    La Mirada, CA
    2011 White Tacoma DCSB TRD Sport
    Blacked out all emblems Westin HDX drop step nerf bar Tinted windows
    I just bought 2011 TRD Sport a couple months ago. From reading threads it appears that I am getting that axle wrap "thud." It only happens once in a while. Most of the time I get smooth stops and starts when driving. The truck is still under warranty at the dealer. I took it in and they said everything was working fine and there did not appear to be any issues. Would changing the leaf springs eliminate this problem? I wonder if the dealer would replace them under the warranty.
  17. Dec 18, 2017 at 8:52 PM
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    I'd take you way back here...
    https://www.tacomaworld.com/threads/goodbye-axle-wrap-mod.108316/
    But the dealer fixing it, probably not.
    betoman[QUOTED] likes this.
  18. Dec 18, 2017 at 9:21 PM
    betoman
    Roberto
    La Mirada, CA
  19. Dec 18, 2017 at 10:44 PM
    VegasVic
    VegasVic Well-Known Member
    SinCity
    2017 Cement TRD Pro
    BAMF Recessed Grille 17" Ray10's 305/70/17 Nitto Ridge Grapplers Lots O' MESO
    This is a common problem. Usually happens between 6-12 mph when coming to a stop. The guy that developed the Shift Sense Pro mapped this phenomenon when looking at shift patterns and I believe he said it happens when the truck down shifts from 3rd to 1st and either skips 2nd or stops briefly in 2nd when it shouldn't on its way to first which causes the sudden jerk/clunk.
    I married my tacoma and T6A1C9O like this.
  20. Dec 19, 2017 at 4:45 AM
    House Forsaken
    House Forsaken Well-Known Member
    Paul
    2015 Tacoma TRD Off Road (Traded) 2017 TRD Off-Road (Traded) 2018 TRD Off-Road
    I took my truck back to the dealer recently for the same issue. They told me there was a new ECU update that would fix it. It did...for a while. It has recently come back, but not with the intensity or frequency as before. Mine only seems to do it when the engine temp is 1/3 and 1/2.
    I'd take it back to the dealer.
